APG/101/Aveling / Broadway/Bellagio?
Thanks
Browse Forums Building A New House Re: Perth WA - two storey builder recommendations? 2Feb 06, 2018 7:46 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Perth WA - two storey builder recommendations? 6Feb 08, 2018 12:16 am Most of the builders you mentioned above are established builders, I would add in vogue & Residential Attitudes to your list to compare. Quite a few people here have built with 101/Aveling/APG, so do a search and you can find their build threads. Have a look at their displays to help narrow down a builder. Make sure when comparing prices specs/inclusions are like for like. As StructuralBIMGuy said do you have a design/floor plan already? What are your block dimensions? Re: Perth WA - two storey builder recommendations? 7Feb 08, 2018 12:56 am Thanks for your response. I am not quite sure about 101 and HGWA they have had bad maintenance issues in one of the other groups . my block is a irregular shape 10m front but after you add the garage the frontage is 12.5 so I can get a decent design on it 300-310m2 is what I am after budget all up finished 450K I wouldn’t mind paying a bit extra if long term means less issues .. I am torn between 101/Broadway and APG they r all quote similar price wise but I am getting a bit more though Re: Perth WA - two storey builder recommendations? 8Feb 08, 2018 1:43 am Sethor Most of the builders you mentioned above are established builders, I would add in vogue & Residential Attitudes to your list to compare. Quite a few people here have built with 101/Aveling/APG, so do a search and you can find their build threads. Have a look at their displays to help narrow down a builder. Make sure when comparing prices specs/inclusions are like for like. As StructuralBIMGuy said do you have a design/floor plan already? What are your block dimensions? Thanks for your response. I am not quite sure about 101 and HGWA they have had bad maintenance issues in one of the other groups . my block is a irregular shape 10m front but after you add the garage the frontage is 12.5 so I can get a decent design on it 300-310m2 is what I am after budget all up finished 450K I wouldn’t mind paying a bit extra if long term means less issues .. I am torn between 101/Broadway and APG they r all quote similar price wise but I am getting a bit more though there is a few calculators you can use if you just google it 7 10509 2 3583 Hello, we can help you please get in contact 0421019219 thank you 3 32680 |
