Browse Forums Building A New House Re: Building inspector worth it? How was your experience? 7Nov 30, 2017 4:01 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Building inspector worth it? How was your experience? 13Nov 30, 2017 1:06 pm rum_home Loveguru I am not sure what you mean here. Can you elaborate. I don't know anything about surveyor. Sure, you didn't get any documentation from your builder regarding the appointment of an independent building surveyor? You should have received a VBA fact sheet on appointment of a private building surveyor? Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 14Nov 30, 2017 1:30 pm Loveguru Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Have they just said you have to supply your own? If that is the case they usually have a lot of conditions to who you must choose from, and their capabilities and liabilities. http://www.vba.vic.gov.au/consumers/bui ... g-surveyor http://www.vba.vic.gov.au/__data/assets ... nt-PBS.PDF Re: Building inspector worth it? How was your experience? 15Nov 30, 2017 1:56 pm rum_home Loveguru Thanks, I will look into this as well further. I didn't receive any information regarding surveyor from builder. Have they just said you have to supply your own? If that is the case they usually have a lot of conditions to who you must choose from, and their capabilities and liabilities. http://www.vba.vic.gov.au/consumers/bui ... g-surveyor http://www.vba.vic.gov.au/__data/assets ... nt-PBS.PDF Builder hasn't mentioned anything about surveyor whatsoever.. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Building inspector worth it? How was your experience? 16Dec 01, 2017 7:21 am Loveguru Builder hasn't mentioned anything about surveyor whatsoever.. In Victoria, it is illegal for the builder to appoint the surveyor, the building surveyor must be appointed by the buyer. You need to check this for very obvious reasons. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building inspector worth it? How was your experience? 17Dec 01, 2017 10:38 am I think having a building inspector is handy particularly for an untrained eye, but keep in mind: 1. They generally pick up the same common faults time and time again (as they do it every day). Their reports tend to be "cookie cutter" in approach. I've compared my own reports of a major inspector against reports from other H1 members and the language is nearly identical. 2. They will always pick something up, as they need to give the perception that the client is getting their monies worth. 3. A lot depends on the willingness of your builder to rectify. If you have a difficult SS and Construction Manager, then a report is useless unless you can compel/enforce the fixes. I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2662 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 11649 Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO… 3 47729 |
