Browse Forums General Discussion Re: Clause in contract about independent inspections 5Nov 29, 2017 6:08 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clause in contract about independent inspections 6Nov 29, 2017 6:16 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clause in contract about independent inspections 8Nov 29, 2017 6:53 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clause in contract about independent inspections 9Nov 29, 2017 7:17 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clause in contract about independent inspections 11Nov 30, 2017 8:05 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clause in contract about independent inspections 12Nov 30, 2017 8:15 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Clause in contract about independent inspections 13Nov 30, 2017 8:22 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Clause in contract about independent inspections 14Nov 30, 2017 8:26 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Clause in contract about independent inspections 17Nov 30, 2017 8:39 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Clause in contract about independent inspections 20Nov 30, 2017 8:53 am Althom They want 2 weeks extra for each report??? Are they saying they believe their work is so bad that there'll be two weeks rework each time your inspector comes in? In Victoria - we have a short fall of tradies - especially framers and brick layers - a shortage so much that u may wait more than 1 month before framers turn up follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 29454 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18744 You talk about deletions, are they variations or PS and PC adjustments? pleas list them 1 17232 |
