Browse Forums Heating, Cooling & Insulation Re: Air conditioning - upgrade from classic to Ultra Air ESP 8Oct 09, 2017 8:14 am Hi waigo, i know the system only needs single phase power, but we kinda want three phase. We are building a single storey home. Are you using single or three phase and if you have single, are you finding it ok? i.e. no short circuiting or anything? Re: Air conditioning - upgrade from classic to Ultra Air ESP 9Oct 10, 2017 9:30 pm lymd1101 Waigo I have upgraded to the ESP Plus System for my new house with 8 zones + the Wi-Fi Module. I also sell these units and I believe it is worth upgrading from the Classic to the ESP Plus as it will be worth it in the long run. Hi, which is more reliable in the long term- Actron 19kw single phase or Actron 19kw single phase Platinum Plus?? I believe both offer the same reliability but if I was choosing between the 2 I would go with the Platinum Plus as that is a newer model. Re: Air conditioning - upgrade from classic to Ultra Air ESP 10Oct 10, 2017 9:32 pm I am using 3 Phase but my house needs a 23kw unit so that size only comes in 3 Phase. 3 Phase power will give you more power to the house which is good if you require it. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 10122 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6570 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
