Browse Forums Building A New House 1 Sep 04, 2017 8:09 am z M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 3Sep 04, 2017 8:49 am Write reply... M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 4Sep 04, 2017 10:36 pm That's concerning, sometimes squeaks etc can be from a lack of adhesive (liquid nails) underneath the yellow tongue this seems much more significant than lack of glue/nails Could be steel rubbing, lack of fixings/joist hanger hardware etc into posi struts/floor joists or a combo of everything Re: Squeaking floor 5Sep 05, 2017 4:20 am x M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Squeaking floor 6Sep 05, 2017 7:00 am Could be multiple things, if there is any access in the subfloor would be good to check in there, otherwise pop some down lights or anything like that out grab a torch and get your partner to walk around again and have a look, see if you can narrow some things down Re: Squeaking floor 7Aug 05, 2018 12:21 pm MrsJM Coral have told me once that steel making noise is normal... but really??? This is normal after 9 months?? This is what it sounds like when my hubby is just walking around normally upstairs and I am downstairs. Edit: video link kindly posted below thank you Has the squeaky been fixed? Stopped 100%? I probably have the same issue, different builder CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17637 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18308 bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 2227 |
