Browse Forums General Discussion Re: Noosa 26 - Hallway wall Recess 7Jul 05, 2017 7:10 pm Update: We ran into light switches problems. Electrician just moved them to alternate locations from plan. So even if you are told they fit they won't install them there, they moved Bedroom 2 and the bathroom (were moved to wall where door opens onto, so door had to bee entirely opened and walk into bedroom before can turn on lights), totally forgot about checking every spot as I found more pressing issues that had to have a phone call about. Re: Noosa 26 - Hallway wall Recess 8Jul 08, 2017 10:00 pm Thank you , I have ended up removing the recesses in the hallway. Also don't have the problem with the light switch in the main bathroom , as we have moved around all the rooms on that one side, but thank you for the heads up. Re: Noosa 26 - Hallway wall Recess 9Aug 28, 2017 4:53 am A tip, If you have long plastered hallway, recesses can break up the plaster so plaster joins etc may be less visible with glancing light - mine look terrible with light coming through the window alongside front door. Different Builder that visited me recently suggested that would have been better to put the niche on long wall. Oh well more artwork required πfor me. Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 52609 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61870 |
