Browse Forums Building A New House Re: New house floor plan advice please. 18Jul 04, 2017 4:37 pm Here is what I have spotted: - consider removing west facing windows for the master bedroom and lounge, move master bedroom's window to the south and lounge's window to the north. Western windows will be a real problem in the summer time. - make sure you introduce long eaves or awnings for your north facing windows (shading will be needed during summers). Alternatively, you can achieve shading with the trees. - consider reducing eastern glazing for the family and kitchen areas and increasing northern glazing instead; - consider moving your alfresco to the family area instead (so it gets a bit more of northern sun during winter); Just my 2 cents. Re: New house floor plan advice please. 19Jul 04, 2017 4:46 pm Thanks Alexp79, The west facing side is the facade, so not sure how it would look if we removed both windows. Currently we have planned to have 450mm eaves, should it be wider than this? Id prefer to remove the north facing windows in the family room so they dont interfere with watching tv. Re: New house floor plan advice please. 20Jul 04, 2017 4:53 pm With regards to the facade, consider reducing them to the minimum size (e.g. making them narrower) as well as tint them up and install Low E glazing. Invest heavily into western side wall insulation, too. I would invest into shutters/blinds to cover TV watching and I assume you would be mainly watching TVs in the evenings, anyway. Passive solar heating will create a huge difference during the cold months, on the other side, though. With regards to the eaves, the perfect size needs to be calculated based on the window height and positioning, but I do believe you would be much better off with much wider eaves (900 mm or even 1200 mm). See details here: http://www.yourhome.gov.au/passive-design/shading 6 57364 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18300 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26275 |
