Browse Forums Building A New House Re: New here we are building the Doulton 56 with extension 387May 19, 2017 6:51 am Lexia Slim Twist with Beechwood Homes http://houseoflexia.blogspot.com.au/ https://www.instagram.com/natlyn7/ Re: New here we are building the Doulton 56 with extension 389May 19, 2017 7:48 am Renman even if there's no errors in your plans it could be possible that the construction team work on old versions of them! Happened to me and luckily I intervened before the poured the slab. Engineering drawings for the slab did not match my plans. Re: New here we are building the Doulton 56 with extension 390May 19, 2017 8:01 am vuster Renman even if there's no errors in your plans it could be possible that the construction team work on old versions of them! Happened to me and luckily I intervened before the poured the slab. Engineering drawings for the slab did not match my plans. Very true same happened to us too. Every time we received plans there was always 1 sheet with older versions. Even with tiles they worked with the older plans again and again. It took us so long to get the corrected plans. Re: New here we are building the Doulton 56 with extension 391May 19, 2017 8:02 am JLH222 From what I've seen, in Melbourne they use a film on the window that can be removed after handover. One had come away from the window in a display so I pulled on it a little and it was just like contact and easy to remove Metricon Metro 32 KDRB Bayside Melbourne http://forum.homeone.com.au/viewtopic.php?f=31&t=84012 Yeah but that's the problem. I already asked m about that. And they told me it's not a film. That it's embedded into the glass. viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 392May 19, 2017 8:04 am natlyn @doulton777 you should start your own thread so we can follow your journey! Your in my thread now . But there's also a link that's my signature that leads straight back too here. viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 393May 19, 2017 8:05 am Renman Doulton Was there many errors with your final plans or it is pretty good? The only error I seen was they didn't put square set cornices in butlers. But since then they have rectified it. viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 394May 19, 2017 8:41 am vuster Renman even if there's no errors in your plans it could be possible that the construction team work on old versions of them! Happened to me and luckily I intervened before the poured the slab. Engineering drawings for the slab did not match my plans. That's unbelievable that could happen. Thanks for the heads up and we make sure that they have everything correct. Re: New here we are building the Doulton 56 with extension 395May 19, 2017 8:52 am Renman vuster Renman even if there's no errors in your plans it could be possible that the construction team work on old versions of them! Happened to me and luckily I intervened before the poured the slab. Engineering drawings for the slab did not match my plans. That's unbelievable that could happen. Thanks for the heads up and we make sure that they have everything correct. It's funny isn't it. We pay them hundreds of thousands of dollars. Yet it feels like we are doing most of the work in just checking up that they are doing things correctly. I never had to do so much work with my past houses. It's so much complicated now days. Because people that are suppose to be so professional and know what they are doing. Just don't. We sit there half the time correcting their mistakes. viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 396May 19, 2017 10:39 am Yup just keep an eye on them like a hawk!!! I found that errors I picked up early were all easily fixed. Just don't let it get to a stage where it's too hard for them to fix. Re: New here we are building the Doulton 56 with extension 397May 19, 2017 12:00 pm Doulton777 JLH222 From what I've seen, in Melbourne they use a film on the window that can be removed after handover. One had come away from the window in a display so I pulled on it a little and it was just like contact and easy to remove Metricon Metro 32 KDRB Bayside Melbourne http://forum.homeone.com.au/viewtopic.php?f=31&t=84012 Yeah but that's the problem. I already asked m about that. And they told me it's not a film. That it's embedded into the glass. viewtopic.php?t=86597 Hmm my contract says obscure film. Oh well, wait and see I guess. Metricon Metro 32 KDRB Bayside Melbourne http://forum.homeone.com.au/viewtopic.php?f=31&t=84012 Re: New here we are building the Doulton 56 with extension 398May 19, 2017 12:25 pm JLH222 Doulton777 JLH222 From what I've seen, in Melbourne they use a film on the window that can be removed after handover. One had come away from the window in a display so I pulled on it a little and it was just like contact and easy to remove Metricon Metro 32 KDRB Bayside Melbourne http://forum.homeone.com.au/viewtopic.php?f=31&t=84012 Yeah but that's the problem. I already asked m about that. And they told me it's not a film. That it's embedded into the glass. viewtopic.php?t=86597 Hmm my contract says obscure film. Oh well, wait and see I guess. Metricon Metro 32 KDRB Bayside Melbourne http://forum.homeone.com.au/viewtopic.php?f=31&t=84012 I actually made a big deal out of it at contract. I told them all their display has the film. I got her too check. And they said no it's not. But in my contract it says provide obscure awning windows. It doesn't say anything about the film or embedded? viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 399May 19, 2017 12:35 pm You know what I find makes no sense what's so ever? You don't have to have obscure windows in your bathroom . I mean how does that make sense? You would think the bathrooms have to be obscure more then the normal living areas. Or that we will give that choice if we wanted . The bedrooms as that should be similar privacy as the bathrooms? But it isn't. And it's stupid to give one neighbour a choice just cos that got there first. So how fair is it that they can enjoy their views when they look out their clear glass windows. But we can't. It doesn't make sense. viewtopic.php?t=86597 Re: New here we are building the Doulton 56 with extension 400May 19, 2017 12:37 pm dulie Yup just keep an eye on them like a hawk!!! I found that errors I picked up early were all easily fixed. Just don't let it get to a stage where it's too hard for them to fix. Oh I do dulie. That's why it's taken 3mths for these variations. Because they kept making mistakes and I made them fix it! viewtopic.php?t=86597 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12806 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 9267 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 6302 |
