Browse Forums Kitchen Corner Re: Overhead cupboards on plan confusing 5Apr 23, 2017 9:05 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Overhead cupboards on plan confusing 7Apr 23, 2017 4:32 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Overhead cupboards on plan confusing 10Apr 23, 2017 6:15 pm chrismarshall3 so what should I tell my builder? It depends on what outcome you want? There have been a few suggestions above, so where have they guided you? At a minimum, I would consider a wider range hood to fully cover the stovetop as mentioned by CuttingEdgeKitchens, which will lead to approximately 450mm cupboard doors over a 900mm cupboard (or slightly larger or small depending on the installation needs of the range hood). I would then put two matching width cupboards doors on either side of the centre cupboard, and fill the small amount of extra space at the ends with a small blank section. But that's just me - it's your house so you need to decide. Re: Overhead cupboards on plan confusing 11Apr 23, 2017 10:37 pm Can I give you a tip? If you have an open access area on top of the cupboard why not extend the cupboards up a bit more and close the open access area on top of the cupboards with a subframe and bulkhead. It means you won't need to go up there to clean the dust. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16739 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 2927 5 10900 |
