Browse Forums Paving & Concreting Re: Concrete slab over deck footings (pour at same time) 2Mar 22, 2017 5:57 pm I've quickly mocked up some rough diagrams of what I'm trying to achieve as it seems my questions are a little unclear. Can I pour the deck footings and spa slab at the same time (deck will not be installed yet). Slab is overlapping the deck foundations to try and get the spa as close to the deck as possible. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would prefer to pour the slab a little bigger which fully covers the foundations like this. Is this also viable (i.e. concrete will not crack and the footings still will achieve the engineers intent. Pour at once, or separate times? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any advise is much appreciated! Re: Concrete slab over deck footings (pour at same time) 3Mar 22, 2017 9:02 pm DLO33 I've quickly mocked up some rough diagrams of what I'm trying to achieve as it seems my questions are a little unclear. Can I pour the deck footings and spa slab at the same time (deck will not be installed yet). Slab is overlapping the deck foundations to try and get the spa as close to the deck as possible. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would prefer to pour the slab a little bigger which fully covers the foundations like this. Is this also viable (i.e. concrete will not crack and the footings still will achieve the engineers intent. Pour at once, or separate times? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any advise is much appreciated! Just showed my partner who is a concrete pumper. He said it can't see any dramas but it really comes down to the engineer. Sometimes they get a bit funny with pouring footings with the slabs. Re: Concrete slab over deck footings (pour at same time) 4Mar 23, 2017 10:06 am I don't really see why you need footings and a slab. If it were me I would
The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 1295 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6649 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 6027 |
