Browse Forums Building A New House Re: landscape plan 8Mar 17, 2017 12:34 pm Jacinta.C Jacinta.C Spotme Diy We were quoted $800 for the landscape design by our builder, but hubby used some online software and did it- we just had to abide by guidelines of developer eg which plants are recommended, required distance from A to B, aize of concrete area v/s green area etc Do you know the name of the software used? We are also in the same position. I've looked at BlueGum Design too, however I'm not after anything extravagant. I think I'd be ok designing my own. I'll have to check with hubby n get back to you! Thanks a ton..! ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Re: landscape plan 10Mar 17, 2017 9:09 pm MR.india Jacinta.C Jacinta.C [quote="Spotme"] Diy We were quoted $800 for the landscape design by our builder, but hubby used some online software and did it- we just had to abide by guidelines of developer eg which plants are recommended, required distance from A to B, aize of concrete area v/s green area etc Do you know the name of the software used? We are also in the same position. I've looked at BlueGum Design too, however I'm not after anything extravagant. I think I'd be ok designing my own. I'll have to check with hubby n get back to you! Thanks a ton..![/quote] It's smartdraw software https://www.smartdraw.com/landscape-design/ Re: landscape plan 12Mar 18, 2017 1:13 am I did mine with Microsoft paint. We were quoted $1000 and I thought bugger that! Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: landscape plan 13Mar 18, 2017 8:21 pm Excellent Gravy, although, my estate requires a plan to be made by a "qualified landscape designer/architect/horticulturist" I will still make one by myself and see if it passes through. ----------------------------------------------------------------- Land - Oct 2016, Stamp Duty-Dec 2016, Land Registration - May 2017?? Domaine Homes - Arizona 26 - Feb 2017 Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25385 Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 10450 |
