Browse Forums Heating, Cooling & Insulation Re: Air con vent Location in a relatively big space 4Feb 15, 2017 7:57 am We had an almost identical situation as yours. We had a row of three vents to service dining room, family room and a large rumpus room. The trouble was, the vent for the large rumpus room was right on the edge of the room, so the hot air was forced to the other side of the room, which happened to be where our lounge was. Since that was where we spent most of our time watching tv, you could really feel the temperature difference. Very annoying. Don't get me wrong, most of the time it was ok, but on really hot days it was not comfortable and the a/c struggled to ever really get that room cool. A few years later I had an independent a/c guy come out because I was concerned with the a/c motor cutting in and out so often. Without me even mentioning the vents, he pointed to the problem. A/C vents not being centered in large rooms (also our master bedroom which because it was so big, it really should have had 2 vents). Another 2 years later, the evaporator unit failed, and I called the same a/c guy out and he attributed the early failure was due to poorly positioned vents, leading to the a/c to work overtime to cool. We had initially spent a fortune on the a/c and had what we thought was the best system available but due to the vents being incorrectly spaced, it may as well have been a cheap and nasty system. Go look at the display homes. Their vents are always positioned perfectly. If you can have your vents repositioned more centrally in large rooms, I would certainly do it. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6531 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
