Browse Forums Building A New House Re: Who is building with Beechwood 14262Jan 24, 2017 8:19 pm Buildingabetterhome.blogspot.com.au Land deposit - Oct 14 Deposit - Jan 16 Land registered - June 16 Settlement - July 16 Colour selection and approval -Sept 16 Slab- Nov 16 Frame - Dec 16 Re: Who is building with Beechwood 14264Jan 25, 2017 4:33 pm 20/11/15 - Settled land 06/11/15 - Request 1st tender BH 21/04/16 - Colour Selections and Contracts Signed 31/05/16 - Commencement Letter 24/06.16 - Started work onsite - cut and benching begun Re: Who is building with Beechwood 14266Jan 25, 2017 7:29 pm 20/11/15 - Settled land 06/11/15 - Request 1st tender BH 21/04/16 - Colour Selections and Contracts Signed 31/05/16 - Commencement Letter 24/06.16 - Started work onsite - cut and benching begun Re: Who is building with Beechwood 14271Jan 28, 2017 10:13 am Buildingabetterhome.blogspot.com.au Land deposit - Oct 14 Deposit - Jan 16 Land registered - June 16 Settlement - July 16 Colour selection and approval -Sept 16 Slab- Nov 16 Frame - Dec 16 Re: Who is building with Beechwood 14272Jan 28, 2017 10:15 am Buildingabetterhome.blogspot.com.au Land deposit - Oct 14 Deposit - Jan 16 Land registered - June 16 Settlement - July 16 Colour selection and approval -Sept 16 Slab- Nov 16 Frame - Dec 16 Re: Who is building with Beechwood 14274Jan 28, 2017 2:33 pm Hi All, As part of my Mortgage Brokers approval requirements i was told i needed to perform a hand over inspection by a qualified builder who is a member of the Master Builders Association. I have just received my hand over report from the inspector and am a little frustrated at the defects which have been noted. I thought i would share them and seek advise on how to proceed to get these issues rectified and offer as a guide for things to check for those who are about to go through hand over / have recently handed over. 1. Mortar beds are defective where there is holes or joins appear unfinished,this is the case in several areas,remedial works are required to fill rectify checking all areas of exterior brickwork. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. Weather strips are poorly installed with holes left on the ends allowing Water entry against BCA weatherproofing requirements. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3. Window Sills are visually stepping and out of level. 4. Internal Doors / wet area doors are not sealed top and bottom to prevent delamination and swelling. (I believe others may have experienced Delamination as per previous posts). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 5. Tiling should be reviewed and obvious steps,poor finish and misalignments rectified (I also noticed that some tiles are not level and have a stepping which isnt great when walking around bare footed.) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 5.A The Australian Standard AS 3958.1 (Guide to the installation of Ceramic Tiles) states a maximum 2mm lippage between standard tiles. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 5.B Bathroom falls are bordering on inadequate with Water ponding evident in the shower. AS 3740 “Waterproofing of wet areas within residential buildings” is a “deemed to comply” standard, and it is called up as a method of meeting the “performance requirements” of the Building Code of Australia (BCA). This standard calls for falls in showers to be between 1:60 and 1:80 and not less than 1:100 in areas outside the shower in its appendix B, and the BCA. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 6. The garage slab is smeared and damaged. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 7. The skirting has a dip in level evident here. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 8. Poor Paint Finish Quality Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ AS 2311 Guide to painting of Buildings-sect 3.12 Paper faced gypsum plasterboard requires checking to ensure that all joints are prepared to a smooth finish and are free of dust before the application of paint. All areas should be reviewed in good light prior to rectification with the above extract from Aust standards considered. 9. Electricals in the roof space should be reviewed for compliance by the Electrician where crossing joists and resting on plasterboard unprotected. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is anyone able to offer advice on the below? 1. What would be the best way to raise these concerns to BW to have them rectified? 2. Is there a means of having tiles removed and redone without causing damage to existing tiles / causing large delays? 3. Which of these issues should i be raising to be fixed before hand over and which should i add to the maintenance list? Your assistance is appreciated as always. Balks. Re: Who is building with Beechwood 14275Jan 28, 2017 3:11 pm Hi Balks - I don't have much advice, although the issues don't seem to be unfixable. For the tiling - did you go through Beaumont Tiles or the other option? The potential problem with all these project builders is that they subcontract everything. I was talking to some friends who just built with another large project builder and you should have heard the list of issues. I would probably raise all of these issues now and see what they say. Some of them will be really easy to fix (e.g. painting). Was your inspector good? Would you recommend them? Re: Who is building with Beechwood 14276Jan 28, 2017 4:51 pm ![]() Hi Balks - I don't have much advice, although the issues don't seem to be unfixable. For the tiling - did you go through Beaumont Tiles or the other option? The potential problem with all these project builders is that they subcontract everything. I was talking to some friends who just built with another large project builder and you should have heard the list of issues. I would probably raise all of these issues now and see what they say. Some of them will be really easy to fix (e.g. painting). Was your inspector good? Would you recommend them? Hi, Thanks for your reply, I went with Westside Ceramics in Lansvale. The inspector that i hired for this report was amazing, ontime, equiped with the right tools and reasonable price. He emailed through the report and then called me for a 30 minute discussion to go over any points i was unsure of, which was helpful seeing as im not in construction. I would definitely recommend him to others for his attention to detail and professionalism. I hope BW take my concerns seriously but time will tell i guess. Re: Who is building with Beechwood 14277Jan 28, 2017 5:29 pm Balks I am not much help but when we build with Beechwood in 2010 they took several months to come back to fix the problems and did a pretty average job anyway. It was easier to fix the problems ourselves. I would bring up the big issues now. Esp the window and electrical. Yes they can remove a single tile and replace it with no damage to surrounding tiles. The more you do before handover the better in my opinion. All the best. Buildingabetterhome.blogspot.com.au Land deposit - Oct 14 Deposit - Jan 16 Land registered - June 16 Settlement - July 16 Colour selection and approval -Sept 16 Slab- Nov 16 Frame - Dec 16 Re: Who is building with Beechwood 14279Jan 29, 2017 8:58 pm Just a rather stupid question here... we paid to have stone benchtop in the kitchen, so my question is do we have both the benchtop next to the stove as well as the island benchtop as stone or did we just paid for the island. Also, is Beechwood getting their stone benchtop from Ceasarstone? Did you guys visit Beaumont to see the sample stone or you picked during your colour selection? Thanks for any of your responses buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14280Jan 29, 2017 9:01 pm ![]() Just a rather stupid question here... we paid to have stone benchtop in the kitchen, so my question is do we have both the benchtop next to the stove as well as the island benchtop as stone or did we just paid for the island. Also, is Beechwood getting their stone benchtop from Ceasarstone? Did you guys visit Beaumont to see the sample stone or you picked during your colour selection? Thanks for any of your responses If you paid for an upgrade to stone it would be the entire kitchen. I upgraded to stone during the colour selection. I didnt visit the showroom. Buildingabetterhome.blogspot.com.au Land deposit - Oct 14 Deposit - Jan 16 Land registered - June 16 Settlement - July 16 Colour selection and approval -Sept 16 Slab- Nov 16 Frame - Dec 16 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 22252 Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4974 ![]() you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5880 |
