So we are currently selling our first henley that we built 2.5 years ago as we have come to realise we would like some more land for our future children!
The reason we chose the Palace Lux Q1 over the Palace Q1 was due to it being slightly cheaper, but also because it had more bulkheads through out the house such as the dining room which we felt was a lot nicer.
Here are some of the changes/additions we have put on so far:
- Raise height od ceilings to 2700
- Added pivot door
- raised height of all doors on ground level
- Upgraded to glass doors for all doors on ground level
- Theatre doors and wiring
- reconfigured the Kitchen
- Door to under stairs (sliding in butlers)
- Glass door from garage to butlers (looks better)
- Square set to the whole house
- Double glazing
- raised height of alfresco doors to 2300
- Extended vanity in the ensuite and moved the window to the middle of the basins
- added a window to the shower, openable
- added 350mm width to the garage (its all our block would allow)
- added a store room to the back of the garage (runs inline with the butlers)
- Going with the Urban facade
- Outdoor tap to balcony (makes it easier to hose down)
- Gas, hot and cold water points to the alfresco
- Upgraded the butlers pantry
- removed the WIR railings in the master
- Upgraded the heating to be zoned
- added an alarm system
- added the premium luxury lighting package
- adding the window splash back to the kitchen, however modifying it to go all the way to the base of the cabinets
- waterfall bench tops
- Pull out bin (largest option)
I cant remember anything else from the top of my head, but we also have the style up option so that will add the Smeg, pot draws and 40mm stone, undermount sink
When I have more I will add it
pri7780
stayxtrue
PEARZ
