Browse Forums Building A New House Re: My Metricon Bordeaux 56 build 12Aug 22, 2016 12:20 am HAL Hi Vuster thanks for the information. I am in the early stage of building a doulton classique 56. I have about 5m distance between the pool(8x4m concrete pool and spa) and the house, so I think I will do it afterwards. I haven't been to selection yet but I am also thinking to tile the ground floor, and I do have corner big block , therefore the parapet mouldings and arched windows might need to be done on the side and rear. Did you opt for the heating and add on cooling coils? I heard from the electrician that it's low maintenance as they use the same duct although initial cost is high. I have a p soil and likely will need engineer footing design , can't imagine how much the site cost will be. Undecided about the hebel power floor. Thanks for the pictures and useful info, will be following your posts My friend has just signed for the doulton 56 as well. It seems good value for money. Apparently there's a doulton display being built in Burwood atm and should be available soon so maybe you should hold out on your selections before seeing it. The doulton classique facade doesn't seem to have any arch windows. All rectangle from what I can see so it'll be less for you to do the side elevation. I'm guessing the eave and band mouldings as well as window mouldings should set you back roughly 6-9K. I've just asked my Meritron coordinator if it's possible to raise a construction variation to do the mouldings for my side elevation too. If she says it's OK I'll know exactly how much it will cost me. I was going to do this after handover but the money I save might be negated if scaffolding is required. My home came with 2 gas ducted heating units as standard. I added the reverse cycle system and assumed that it replaces the gas heating units but I've checked my plans and it appears the gas heaters are still there. I'm going to have to follow this up. Re: My Metricon Bordeaux 56 build 13Aug 22, 2016 8:38 am Wow, thank you for sharing the information on the 'upgrades'. Metricon surely makes heaps of upgrades worth their while. I am sure when it comes to build like their display home, it would cost close to double the standard house they are selling. Love to see your progress and congratulations on the brave journey, hopefully everything goes smoothly for you. Also, do you plan to use a landscaper as we think if we max out our budget building, we just have to live with bare landscape for a while Re: My Metricon Bordeaux 56 build 14Aug 22, 2016 11:55 am Yes The slab of the doulton display just went in not long ago. It will be too late for me to wait for it prior to my selection did you add on another water heating unit? My friend who built their own house told me it's their biggest mistake not to have another unit as the water takes too long to go upstairs and longer time to heat up if someone also use it in another room . I am not sure whether I should add that. Thanks Re: My Metricon Bordeaux 56 build 15Aug 22, 2016 12:46 pm Hi Hal, I've got 2 hot water units installed which was a standard inclusion. 1 is an instantaneous system and the other is a solar powered system. Re: My Metricon Bordeaux 56 build 16Aug 22, 2016 8:03 pm Hi HAL, We are new to building and this is our first house. We are thinking of either the Bordeaux 50 or the Doulton 56 though it's a bit big for us (family of 5). What's the contract price for the Doulton if you don't mind we are asking and did you do any optional upgrades etc? Many thanks and good luck! Re: My Metricon Bordeaux 56 build 19Aug 22, 2016 9:32 pm Wow, totally missed this one. Beautiful house you're building mate, look forward to seeing more. Re: My Metricon Bordeaux 56 build 20Aug 23, 2016 8:54 am Wow. Your home is going to be amazing and a great location. I'll be following with interest as I know where you're building (we're doing our own knockdown rebuild in the next suburb). I thought your place was going to be about 50 squares when I drove past but I underestimated! Look forward to seeing your updates. Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12866 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9745 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19800 |
