Browse Forums Home Theatre & Automation Re: The NBN Rollout and What it means to the new Home owner 45Apr 04, 2016 11:09 pm Looking nice Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: The NBN Rollout and What it means to the new Home owner 46May 14, 2017 10:59 pm How do I work this if I am building a new house in an area where NBN isn't available yet (knocking down old house - so not a new estate) We will also only have access to HFC. We are also subdividing which, as part of that process means houses need to be NBN ready. We want data points in an up stairs bedroom, to be able to connect 2 pc's via ethernet and also be able to connect the TV via ethernet too. Ideally we'd have the central hub/wireless router with the TV. However, since NBN isn't available yet, but our house will be NBN bready(don't even know what that entails), what should we do with our build? Re: The NBN Rollout and What it means to the new Home owner 47Jul 30, 2022 6:22 pm Sorry to revive an old post. I have a similar NBN enclosure installed by my builder back in 2016; since then I got the NBN and I have been leaving the NBN modem 'hanging' at the bottom of the enclosure. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How did you manage to 'stick' your appliances into the back panel? consider no 'bracket' / 'rail' is provided; using 3M adhesive? Thank you Sorry but you have a crap builder. Probably too late now. For our last build I only spoke to builders who would allow me easy access (at no cost). I used my own sparky… 10 10477 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9960 |
