Browse Forums Building A New House Re: Building At Edmondson Park 2847Mar 16, 2016 3:13 pm Our McDonald Jones Cordova Two Build - http://cordovatwomjh.blogspot.com.au Re: Building At Edmondson Park 2859Mar 24, 2016 1:20 am Bhoot Hi All....I have just received the plan for my home...I have been told that I can not go with a 2700mm ceiling due to the height of the house...max I can go is 2590mm...I have attache the plan..can somebody advise what can be done in order to keep the 2700 ceiling height... Is there a big difference between 2590mm and 2700mm...Thanks Are you building a double storey ? Even if my ceiling was 3m for the ground floor i would have been allowed to do it. Ridge height can be 8m to 8.5m depending on council/CDC rules. Re: Building At Edmondson Park 2860Mar 24, 2016 1:21 am Bhoot Hi All....I have just received the plan for my home...I have been told that I can not go with a 2700mm ceiling due to the height of the house...max I can go is 2590mm...I have attache the plan..can somebody advise what can be done in order to keep the 2700 ceiling height... Is there a big difference between 2590mm and 2700mm...Thanks The difference between 2.59m and 2.7m is 11 cm or just over 4 inches ...it does make a difference but 2.59m should be good enough. Hello I have a question, when you upgrade an existing lights ( from metal halide to LED) on existing lighting poles in a recreational park. Do you have to design check… 0 6586 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 22230 No, not yet. It’s currently being assessed by our building surveyor 4 19480 |
