Browse Forums General Discussion Re: Insulate wall or pipes to reduce noise? 3Feb 23, 2016 1:16 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Insulate wall or pipes to reduce noise? 5Feb 23, 2016 4:45 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Insulate wall or pipes to reduce noise? 8Feb 26, 2016 2:40 pm I have insulated the upstairs toilet, vanity plumbing with the foam stuff that concreters use for thier joins as well as normal batt insulation in between floor. It comes in a roll and you just wrap it around the pipes and then wrap duct tape to hold it all in place. Works very well for little effort. Cannot hear any flushing noises whatsoever. A friend calls doing this "lagging". Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 14017 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13934 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 12588 |
