Browse Forums Building A New House Re: Porter Davis homes 12090Dec 07, 2015 7:51 am Building a Porter Davis Livingstone 23 in Mayfield, Cranbourne East | Our thread 18/05/15 - Contract Signed 24/12/15 - Land Settlement 30/1/16 - Slab poured 9/06/16 - Handover Re: Porter Davis homes 12092Dec 07, 2015 8:47 am I'd be taking the attitude that you are building a new house! My builder mates won't even reuse a light switch in a different job if it's been installed for 10 minutes Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Porter Davis homes 12093Dec 07, 2015 9:03 am It's a BIG assumption that they are second hand, did anyone consider a large bulk purchase that is still being run down? Re: Porter Davis homes 12094Dec 07, 2015 9:14 am It's a BIG assumption that they are second hand, did anyone consider a large bulk purchase that is still being run down? Good point, Chris... End of the day, the house is warrantied, so you get them back to fix the big ticket items anyway Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Porter Davis homes 12096Dec 08, 2015 7:15 am Hey, experts out there, what do you think of this - has my door bowed and is it acceptable? So the bottom of the door comes out by about 5mm (top is fine) which means the front of the door isn't touching the door seal and we are getting lots of dust, moisture and insects through the gap. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Porter Davis homes 12097Dec 08, 2015 7:54 am In theory, a good carpenter will gap a door so you can run your finger along a consistent gap around the top and sides... But if you're getting bugs, dust and moisture, you've got an issue you're not happy with - it would bug me... Is the door warped or the frame or of square? Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Porter Davis homes 12098Dec 08, 2015 8:27 am Thanks Drew, I'll take a better photo tonight. The door looks square when looking face on, but looking from the side the bottom left part of the door is protruding from the inside. The frame seems to be fine. As a quick fix I have applied an extra 6mm rubber seal over the bottom portion of PD's black rubber seal, it's a bit better but not perfect. Re: Porter Davis homes 12099Dec 08, 2015 8:40 am If you've got a long spirit level, use the side of it as a straight edge to see what is out of square Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Porter Davis homes 12100Dec 08, 2015 8:43 am I'll try that tonight, thanks! (I'm constantly amazed by how much you know) check out the facebook page Building with Better Built - it helps! But i've heard both builders are fantastic. 1 160075 Yeah, that’s fair to be uneasy about it. We had similar wording pop up early on and our conveyancer pushed back hard. A few things were amended once we queried it,… 3 2640 Hi paul smith, Did you go ahead with Dezire Homes? I am in the market now and was looking for some feedback? Thanks 4 176470 |
