Browse Forums General Discussion Re: Things to think about 13Dec 30, 2008 9:16 pm Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: Things to think about 17Dec 30, 2008 10:54 pm Taken from: http://www.adelaidecitycouncil.com/scri ... 04_01#When
Quote: WHEN IS DEVELOPMENT APPROVAL REQUIRED? If you are intending to undertake any of the following activities you will need to obtain Development Approval from Council before commencing the work: Demolish, construct, add or alter a building; Erect a sign; Change the use of a property; Any tree damaging activity to a significant tree any external alteration (and in some case also internal alterations) of a listed heritage item; divide or alter the boundary of an allotment Your application may require one or more consents to be obtained before you can proceed with your proposal including Provisional Development Plan Consent, Provisional Building Rules Consent, Public Space Encroachment Consent and Land Division Consent. No development can be commenced without written Development Approval Re: Things to think about 19Dec 31, 2008 10:35 am I would be trying to get as much natural light into the space as possible - like you said, sliding door - maybe a window in the same wall or on the side wall if possible - and consider privacy re the sliding door if applicable; frosted coating on part or all of the door can be very effective.
Also remember all the data and services that you will want brought into that space - get them roughed in when the rest of the house is being done if possible. Seperate light switch(s) for the room at the door you will mostly be entering the space through. Cheers, Earl Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 12446 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 7233 |
