Browse Forums General Discussion Re: Painting Render... 6Jun 22, 2015 6:26 pm I have Dulux Shale Grey and I too can see some roller marks, but not extremely noticeable so am living with it for now. Inside paint job I am getting rectified though Dale - Building Newbie Proserpine, QLD Re: Painting Render... 7Jul 01, 2015 7:23 pm Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? Re: Painting Render... 8Jul 03, 2015 7:11 pm To avoid roller marks each wall must be painted (including cutting in) whilst the wall is in shade. That is what I learnt (the hard way) on my build. I started painting over the Christmas/New Year break i.e. mid summer and had to repaint the entire house, inside and out once it cooled down a bit. Re: Painting Render... 9Jul 10, 2015 5:35 pm rocksteady Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? They said they would try and fix it but also blamed a bit of the render work?? Re: Painting Render... 10Oct 21, 2015 9:17 am Jason007 rocksteady Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? They said they would try and fix it but also blamed a bit of the render work?? Sometimes you need to sweep away the loose sand but once you seal it (bondcrete) it's out of the renderers hands, unless chunks of render are falling off or the surface is not flat, they have done their job & cant be blamed! Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5467 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 9240 |
