Browse Forums Building A New House Re: Dulux Natural White for walls 8Jun 09, 2015 7:51 pm I can't believe these things aren't essential with all builders! Ill see what the quote is, and in the meantime hope to find some people who used natural white and liked it! Lol Re: Dulux Natural White for walls 9Jun 09, 2015 7:54 pm I'm sticking with the standard 2 coat system and will add a 3rd coat to each room after handover. Too expensive to upgrade and for the cost of paint and a little time I'll be able to add my feature walls Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Dulux Natural White for walls 10Jun 09, 2015 8:04 pm Hey Roomeat, Which colour are you doing two coats in? Was the colour included in your range to choose from? Thanks Re: Dulux Natural White for walls 11Jun 09, 2015 8:47 pm Roomeat I'm sticking with the standard 2 coat system and will add a 3rd coat to each room after handover. Depending on the builder, one difference may be that with 3 coats you may get sealer+2 colour coats on top, but with 2 coats they leave off the sealer, and just have the 2 coats of paint. So adding an extra coat of colour afterwards may not be quite the same thing. It's a good idea though, and is a way around their big markup. Dulux Natural White for walls 12Jun 09, 2015 10:04 pm First_Home_Adventure Hi Beazley77, I might check that out with my builder... So did you do lexicon 1/4 for skirtings too? What about for your ceiling? I did want the crisp white feel, so maybe should try use a different colour for my doors, skirtings etc Just so disappointed! Lol We don't have skirts but when we do they will be lexicon 1/4 too. Doors got two coats over an undercoat and frames the same but with the oil finish. Whatever it was to meet the painting std and they look fine. Better than I thought, and we'd used it before over blue doors in a renovation! Ceiling is ceiling white and that's just builders std and it looks great too. Re: Dulux Natural White for walls 13Jun 10, 2015 3:08 am oneJohn Roomeat I'm sticking with the standard 2 coat system and will add a 3rd coat to each room after handover. Depending on the builder, one difference may be that with 3 coats you may get sealer+2 colour coats on top, but with 2 coats they leave off the sealer, and just have the 2 coats of paint. So adding an extra coat of colour afterwards may not be quite the same thing. It's a good idea though, and is a way around their big markup. From what i understand from a couple of painter friends, the 2 coat system is 1 undercoat that has the topcoat colour added to it then 1 topcoat. You have to use a undercoat otherwise paint quality would be way below acceptable levels. It's a waste of money for me too get the 3 coat system. We are planning a complete black theatre that includes wallpaper and some rooms (like the master bedroom) will also end up with wallpaper feature wall. I'll just assess each room as we complete them. If they need another coat we'll do it ourselves Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Dulux Natural White for walls 14Jun 10, 2015 4:51 pm What does 3 coats equate to from your builder? I always though - Base coat, then 2 paint coat? Re: Dulux Natural White for walls 15Jun 10, 2015 5:29 pm Building4my3tots What does 3 coats equate to from your builder? I always though - Base coat, then 2 paint coat? That is correct. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Dulux Natural White for walls 16Jun 10, 2015 5:32 pm First_Home_Adventure Hey Roomeat, Which colour are you doing two coats in? Was the colour included in your range to choose from? Thanks Colour appointment on Friday but will be selecting what ever is closest to straight white. Would rather builder just give me a solid base to work with after handover. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Dulux Natural White for walls 17Jun 10, 2015 9:20 pm Who are you building with roomeat? So for some colours they need to do base coat plus 3 coats? Let us know how you go with your colours? Re: Dulux Natural White for walls 18Jun 10, 2015 9:43 pm First_Home_Adventure Who are you building with roomeat? So for some colours they need to do base coat plus 3 coats? Let us know how you go with your colours? Building with Clarendon. Yeah some colours or even different shades of colours will be a upgrade. And from what i understand if you want a low sheen that's a upgrade as well lol Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Dulux Natural White for walls 19Jun 11, 2015 1:06 am We went lexicon 1/4 on everything! Obviously gloss on doors and skirts and frames and matts for walls but its very white and ours was 2 coats only. I love it! Second Build, this time with Carlisle 2016, can't wait! Beckham: viewtopic.php?f=31&t=67280 Canterbury: viewtopic.php?f=31&t=81175 Re: Dulux Natural White for walls 20Jun 11, 2015 6:59 am Even on your ceiling pearz? I'm so jealous!! Lol Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7372 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13908 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4804 |
