Browse Forums Building A New House Who's building with Clarendon?? 8201Jun 04, 2015 6:54 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who's building with Clarendon?? 8202Jun 04, 2015 6:56 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who's building with Clarendon?? 8206Jun 04, 2015 7:51 pm rmjose18 I'm assuming the retaining wall you see with fence behind .. That's the neighbours box planter retaing wall and the fence is sitting on the boundary. I don't think u can have the fence sting anywhere else other than boundary! Ours would look similar but that's coz our retaining wall will be a boxed planter about 600mm high n my neighbour will be 800mm high n fence will sit on top as that's on boundary! Hope i make sense Yeah the way I understand it is that the retaining walls are usually built so far into the property on the lower side. So in BB's case the retaining wall is probably inside the boundary line of the lower block. This is how our retainers are for my land. Block to my left is lower than me and the retainers are built in his yard so my fence will sit back from the top of the retainer. The block behind me however, is above me and that retainer is built inside my boundary, so my side fence will go up and onto the retainer to the corner. It's actually going to be a interesting back fence as the retainer only goes half way across my back yard. So fence will go up, across back then back down to the other rear corner. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Who's building with Clarendon?? 8207Jun 04, 2015 8:44 pm Hi everyone! So excited that everyone is in construction! A few away from potentially starting construction (fingers and toes crossed!) Seeing that most of you have started construction in Oran Park.. I thought it would wise to ask if you guys would help me understand something before we lodge into CDC with my plans... There is an obvious step down on the ground works of the proposed plans I've received (pix below) is there a reason why the design isn't flat? On one side there is a significant change in gradient as well.. Wouldn't it be obvious to just cut and fill the section where it steps down? Any suggestions for a possible alternative option if it can't be helped? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who's building with Clarendon?? 8208Jun 04, 2015 8:45 pm Hi everyone! So excited that everyone is in construction! A few away from potentially starting construction (fingers and toes crossed!) Seeing that most of you have started construction in Oran Park.. I thought it would wise to ask if you guys would help me understand something before we lodge into CDC with my plans... There is an obvious step down on the ground works of the proposed plans I've received (pix below) is there a reason why the design isn't flat? On one side there is a significant change in gradient as well.. Wouldn't it be obvious to just cut and fill the section where it steps down? Any suggestions for a possible alternative option if it can't be helped? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who's building with Clarendon?? 8209Jun 04, 2015 9:06 pm rmjose18 and Denot Congrats on getting the PCI and handover dates ! Its only a beginning ... lol, not the end, as we found out today. Finally moved into our new house. First night .... almost looks like a hotel, everything so new, but for the suitcases and bags scattered everywhere, which brings us back to reality. Between tiles and hardwood flooring, especially with kids and pets - Tiles all the way ! We have tiles in common areas and laminate in bedrooms. Laminate is as hard wearing as tiles, and its cheap which means you can change in 5 years time ! Oh and first post using NBN Re: Who's building with Clarendon?? 8210Jun 04, 2015 9:06 pm Hi everyone! So excited that everyone is in construction! A few away from potentially starting construction (fingers and toes crossed!) Seeing that most of you have started construction in Oran Park.. I thought it would wise to ask if you guys would help me understand something before we lodge into CDC with my plans... There is an obvious step down on the ground works of the proposed plans I've received (pix below) is there a reason why the design isn't flat? On one side there is a significant change in gradient as well.. Wouldn't it be obvious to just cut and fill the section where it steps down? Any suggestions for a possible alternative option if it can't be helped? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who's building with Clarendon?? 8211Jun 04, 2015 9:07 pm Hi everyone! So excited that everyone is in construction! A few away from potentially starting construction (fingers and toes crossed!) Seeing that most of you have started construction in Oran Park.. I thought it would wise to ask if you guys would help me understand something before we lodge into CDC with my plans... There is an obvious step down on the ground works of the proposed plans I've received (pix below) is there a reason why the design isn't flat? On one side there is a significant change in gradient as well.. Wouldn't it be obvious to just cut and fill the section where it steps down? Any suggestions for a possible alternative option if it can't be helped? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who's building with Clarendon?? 8212Jun 04, 2015 9:10 pm I think the slanting dash-dotted line is the natural slope of the land. The solid black line is the building platform which will form after cut-and-fill and on which your house will sit. Re: Who's building with Clarendon?? 8213Jun 04, 2015 9:25 pm We r using superior... Will post in a months time.. For what I wanted they were very well priced! Internal fitouts for wardrobes are between 350-650.. With installation.. Clarendon quoted his n her wardrobe for $16k!!!! Re: Who's building with Clarendon?? 8214Jun 04, 2015 9:46 pm For wardrobes, laundry, kitchen cabinets etc. try Choice wardrobes as well. We have used them in our previous home and now in the new one as well. Re: Who's building with Clarendon?? 8215Jun 04, 2015 10:24 pm Sydney-build keep us posted on any issues you find in the house. I agree - is like a hotel. Took me a good couple of weeks to sleep well. Our landscaping is nearly finished and I actually parked my car on the driveway tonight - so sad that I get so excited. I am a floorboard lover but after doing tiles (due to a very persistent husband) I have been converted. So easy to maintain and clean. No scratches to worry about - absolutely loving them. I would just make sure you get Matt not gloss as they show up every mark. A couple of photos on my plants - not to exciting Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built a Fairmont 35 in Pennant Hills. Completed May 2015. http://www.pennodream.wordpress.com - Blog updated regularly Re: Who's building with Clarendon?? 8217Jun 04, 2015 11:37 pm Well we finally have handover set for 16 June. This is 10 months since the contact was signed. Really didn't think it would take so long but guess it can take even longer. Wishing I understood more before this all began. Today I picked up being double charged, so watch the bills closely. And now all our work begins.. driveway, tile, carpet, blinds, etc. still to go. All the people we worked with at Clarendon are super nice, but wow this is not an easy process! How good is good enough on the tiling job? There are a few lips, not as level as I would accept. Any thoughts? Also wondering how picky to be on the ceiling line above the front door being level. Think we should be getting it redone, but not sure if it is a fair complaint? Did anyone in Qld get their own inspection service? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ------------- Building modified Wentworth 35 with Clarendon Homes 13/11/14 Site Cut - 01/12/14 Slab Poured - 02/06/15 Fencing Removed - 16/06/15 Handover Re: Who's building with Clarendon?? 8218Jun 05, 2015 7:49 am Hey SB, hope you are settling in well. What company did you use for your butlers pantry? Are you satisfied with their work? The one that I initially finalised has done a runner so urgently in need of someone good. Thanks. Sydney-build For wardrobes, laundry, kitchen cabinets etc. try Choice wardrobes as well. We have used them in our previous home and now in the new one as well. Re: Who's building with Clarendon?? 8219Jun 05, 2015 8:04 am For our butlers pantry we used Diamond Marble & Granite. http://www.diamondgranite.com.au/ They do everything... polyurethane, polytec, stone benchtops, glass splashbacks etc Choice Wardrobes may also do cabinetry, but they dont do stone benchtops. Re: Who's building with Clarendon?? 8220Jun 05, 2015 8:11 am Did anyone (in NSW) get any concreting done through Clarendon? Like driveways and down the side of their house? It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact… 3 8075 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8406 |
