Browse Forums Kitchen Corner Re: Floating floor before waterfall bench 2Apr 29, 2015 10:43 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating floor before waterfall bench 4May 06, 2015 4:08 pm Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: Floating floor before waterfall bench 9May 20, 2015 4:35 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating floor before waterfall bench 11May 21, 2015 7:13 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating floor before waterfall bench 12May 21, 2015 4:37 pm Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: Floating floor before waterfall bench 13May 22, 2015 8:23 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating floor before waterfall bench 16May 25, 2015 8:54 pm when a waterfall is installed with a 45 degree miter, the weight of the bench or cabinets is never applied to the floor through the waterfall. Reason; the risk of the downwards pressure pushing the waterfall out due to the 45 degree join. You will get away without any hassles so long as your underlay is of good quality and is no thicker than 5 mm. Re: Floating floor before waterfall bench 17May 26, 2015 2:29 pm rebuilder86 when a waterfall is installed with a 45 degree miter, the weight of the bench or cabinets is never applied to the floor through the waterfall. Reason; the risk of the downwards pressure pushing the waterfall out due to the 45 degree join. You will get away without any hassles so long as your underlay is of good quality and is no thicker than 5 mm. Umm, that's not quite right. If its a tiled or solid timber floor then part of the load is shared by the floor. With a solid floor there is no risk of the mitre moving! If its a floating floor then the load is supported by the cabinet. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating floor before waterfall bench 18May 26, 2015 2:50 pm hang on are you saying the weight is supported by the waterfall in some installations? Re: Floating floor before waterfall bench 19May 26, 2015 3:08 pm rebuilder86 hang on are you saying the weight is supported by the waterfall in some installations? No, the weight of the waterfall sides is supported by the floor in installations on tiles or solid timber floors. They are also glued at the mitre and to the cabinet but primarily the floor is doing the work. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3081 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 424 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4548 |
