Browse Forums Building A New House Re: Coral Homes general build thread 1056May 06, 2015 8:56 pm Nic and Shell 1 browndog Things down the walls can be tricky so only way is to get in their before gyprock goes up and run phone cable being cheapest or what ever yourself, put in conduit string through it, then you can pull what ever you want through. But most people wont do that its fiddly. This is what I have done for my extra points just some conduit thru the walls going to make it much easier Also did you just mark out all the wall and conduit locationa by a line on the slab? Good to hear someone has done it. Re: Coral Homes general build thread 1057May 06, 2015 9:00 pm It's not condoned exactly, but also depends if you have a good SS. I also stuck stud brackets in anyway Re: Coral Homes general build thread 1058May 06, 2015 9:17 pm Nic and Shell 1 It's not condoned exactly, but also depends if you have a good SS. I also stuck stud brackets in anyway Might be silly question do you always need to put stud brackets in for powerpoints or switches or can they just be put on to noggins? Did you put in any more noggins in yourself when they were framing it up? Re: Coral Homes general build thread 1059May 06, 2015 9:24 pm Normally they go on the studs if you preplan them, can stick them on noggins or can also do them after as there's ones that hook over the plaster. I got the carpenter to stick extra noggins in my media cupboard basically just for mounting brackets but it wasn't exactly needed. And also got him to put in extra studs where I'm going to hang the TV's on the wall You should check your detail drawings, it may show downpipe within brick pier. 14 14839 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 15149 Hi so sorry for the late reply. I already contacted them and they wouldn't tell me instead they tried to get me to talk to one of their home coordinators and I'm not… 2 6539 |
