Browse Forums Building A New House Re: Our "Daydream"279".... It's OURS!!! carpet in 39Dec 03, 2008 7:20 am Looks good so far, are the drainpipes I can see in the pictures for a sealed rainwater system? Is this now a requirement in QLD?
regards sean Re: Our "Daydream"279".... It's OURS!!! carpet in 40Dec 03, 2008 10:16 am sdabel Looks good so far, are the drainpipes I can see in the pictures for a sealed rainwater system? Is this now a requirement in QLD? regards sean Not sure what you mean by a sealed rainwater system.? We have no town water or sewage at our new place and will rely totally on rainwater and our water treatment system. We actually prefer this way cause our rates are really cheap! about 900 or so per year Thanks everyong for the comments about the trees.. We just love this rural estate.Its called Oakhurst Gardens. love the flat block and the SPACE!! just over 1 acre. and best of all its only about 4 klms from town. Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! 1 16560 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 7017 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8236 |
