Browse Forums Safer Living Re: IP CCTV system recommendations 93Apr 23, 2015 11:59 am Bels My order of 7 Hiks just made it out before the 2 week Chinese New Year Holiday. Pity my Dahua PTZ didn't. They're all going to be hooked up to my Synology NAS using Surveillance Station. One of the great things about QNAP/Synology NAS is Surveillance Station. I know with QNAP, you can use their cloud services to register your NAS. I then use that service and the Vmobile app on my Android/Apple devices to monitor my cameras (and house) over the internet. Opens up a lot of possibilities. I'd recommend having a fisheye camera at the entrance and living area, if your alarm goes off (they can hooked up via the internet and a phone app too), you can then connect to your cameras, check for any activity and call police. You could also connect some of your entry, living room and backyard lighting to Z-Wave and turn it on remotely as well. Re: IP CCTV system recommendations 94Apr 23, 2015 12:36 pm Hi Guys, sounds great Just have a question regarding physical connectivity: will you all be wiring it thru the NBN..? If so, if the power is cut, will you have UPS's to support operation/LAN & WAN access..? Not sure how to solve this problem... Or if there is a simple solution you might know of..? Thanks heaps Sent using Tapatalk Re: IP CCTV system recommendations 95Apr 23, 2015 12:39 pm BJ88 we terminate the IP camera cabling to the patch panel, this way you have versatility in that the recorder unit can be moved to any and every room that has a data point. Can you elaborate on how this works? If you have 8 cameras, then I would assume you would have 8 cat6 leads going into the back of the NVR? If you run the cameras back to the patch panel how do you get those 8 lines back to the NVR? Assuming the room where you put the NVR would have to have 8 data points? Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: IP CCTV system recommendations 96Apr 23, 2015 12:51 pm Youll need a seperate POE switch depending on what sort of cameras you use. Normally you would put the Qnap NAS next to the data ports where they get cabled back to. And all connect to the same switch. One thing I looked at is the price difference between a Qnap/Synology NAS vs. a Hikvision/Dahua NVR. The Qnap solution In theory is better as you have backup redundancy and a place for file storage and Media playback, but you need to supply your own POE switch for camera power and the NAS only supplies 2 free camera licenses. All extra cameras are $60-$70 each camera license. Using Tapatalk Re: IP CCTV system recommendations 97Apr 23, 2015 2:21 pm Roomeat Can you elaborate on how this works? If you have 8 cameras, then I would assume you would have 8 cat6 leads going into the back of the NVR? If you run the cameras back to the patch panel how do you get those 8 lines back to the NVR? Assuming the room where you put the NVR would have to have 8 data points? All your 8 cameras would have separate Cat6 cables running back to a central POE switch (or normal /w POE injectors) - your NVR would then hang off the same switch via a single Cat6 cable, whether it's a PC, NAS (QNAP) or dedicated NVR unit. With this configuration it wouldn't matter where in the house the NVR unit is located, as long as it is plugged into the same switch as the IP Cameras. Hope that helps. Alkira Homes - The Olivia Re: IP CCTV system recommendations 98Apr 23, 2015 2:31 pm Roomeat BJ88 we terminate the IP camera cabling to the patch panel, this way you have versatility in that the recorder unit can be moved to any and every room that has a data point. Can you elaborate on how this works? If you have 8 cameras, then I would assume you would have 8 cat6 leads going into the back of the NVR? If you run the cameras back to the patch panel how do you get those 8 lines back to the NVR? Assuming the room where you put the NVR would have to have 8 data points? As a general rule, all your cabling should run from a data point back to a single point in your house That single point should have some ventilation and low dust That single point will have some sort of cabinet with a patch panel The numbers on the patch panel will equate to the number on the data point IE. Living Room 1 Data point = Living Room 1 on the patch panel From that patch panel you would run another cable into a switch located in the cabinet IE. Ports 1-10 on the patch panel have a cable plugged into any port on the switch That switch means that your devices connected to the cables can now talk to each other regardless of location So let's say your cameras are connected to Ports 1-8. Now let's say you have a data point in your living room, port 9. You plug your NAS/NVR into Port 9, then at the patch panel you plug Port 9 into the switch. Because that switch is your central communicator your cameras and NAS/NVR can now talk, it doesn't matter where your NAS/NVR is located. It can be in the cabinet, but it can also be located in the living room. PS. If your NAS/NVR is located in the cabinet, you would just plug it directly into the switch. Also with that sort of cabling, you can run a normal Telstra/voice line to any datapoint in the house from your patch panel. Voice will run easily over CAT6/CAT5E. A long as the Telstra/voice line is in your cabinet. Just to clear up some points earlier about POE camera points externally, you don't need a data point, just a CAT6/CAT5E cable coming out of your eave and wall where the camera will be drilled into. That cable will be neatly connected to the camera to make it all water resistant. Also you can either have a POE switch, or purchase cheap POE injectors which are very quite. These would be located in your cabinet. Re: IP CCTV system recommendations 99Apr 23, 2015 2:44 pm PixiGT Hi Guys, sounds great Just have a question regarding physical connectivity: will you all be wiring it thru the NBN..? If so, if the power is outage, will you have UPS's to support operation/LAN & WAN access..? Not sure how to solve this problem... Or if there is a simple solution you might know of..? Thanks heaps Sent using Tapatalk Most UPS don't have enough power to run for long periods. Realistically they are a short term proposition to neatly shut down devices until power is restored. To keep a POE camera running during a power cut, you would need to have your switch, POE injectors and NAS/NVR running, plus if you plan to use the internet, your ADSL router. If you have them in different locations, that mean more expensive UPS. Having big enough Solar panels fixes that problem during the day. But at night is the real problem. In the meantime, let's see what the Gigafactory delivers over the next few years... http://en.wikipedia.org/wiki/Gigafactory Re: IP CCTV system recommendations 100Apr 23, 2015 3:11 pm candycandy PixiGT Hi Guys, sounds great Just have a question regarding physical connectivity: will you all be wiring it thru the NBN..? If so, if the power is outage, will you have UPS's to support operation/LAN & WAN access..? Not sure how to solve this problem... Or if there is a simple solution you might know of..? Thanks heaps Sent using Tapatalk Most UPS don't have enough power to run for long periods. Realistically they are a short term proposition to neatly shut down devices until power is restored. To keep a POE camera running during a power cut, you would need to have your switch, POE injectors and NAS/NVR running, plus if you plan to use the internet, your ADSL router. If you have them in different locations, that mean more expensive UPS. Having big enough Solar panels fixes that problem during the day. But at night is the real problem. In the meantime, let's see what the Gigafactory delivers over the next few years... http://en.wikipedia.org/wiki/Gigafactory Thanks for reply Was just thinking about those who may cut power prior to their clandestine visit.... Sent using Tapatalk Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21206 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 20504 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 10529 |
