Browse Forums General Discussion Re: What is this pipe used for? 3Apr 04, 2015 4:06 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: What is this pipe used for? 4Apr 04, 2015 4:16 pm Thank you Adriang and bashworth! Very helpful answers to me Re: What is this pipe used for? 5Apr 04, 2015 8:19 pm Agree with the answers but it is a stupid place to have it. One dark night...... 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: What is this pipe used for? 9May 01, 2015 2:32 pm mgilla ORG can be cut off to ground level. Just can't have surface water running into it. No it can't. The regulations state 75 mm above ground level or 50 mm above paving. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: What is this pipe used for? 10May 01, 2015 6:17 pm SaveH2O mgilla ORG can be cut off to ground level. Just can't have surface water running into it. No it can't. The regulations state 75 mm above ground level or 50 mm above paving. I suppose that depends on what state you are in. Re: What is this pipe used for? 11Aug 23, 2015 12:01 am mgilla SaveH2O mgilla ORG can be cut off to ground level. Just can't have surface water running into it. No it can't. The regulations state 75 mm above ground level or 50 mm above paving. I suppose that depends on what state you are in. A bit late seeing the above but I will answer it anyway. On May 1 2011, the Plumbing Code of Australia (PCA) was introduced into the National Construction Code (NCC) as volume 3. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5671 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3722 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 6513 |
