Most retailers should be able to look after you, find the best deal
Browse Forums Building A New House Re: Who else is building at Oran Park? 3623Feb 15, 2015 11:26 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who else is building at Oran Park? 3629Feb 16, 2015 12:46 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who else is building at Oran Park? 3632Feb 16, 2015 12:51 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who else is building at Oran Park? 3635Feb 16, 2015 1:47 pm $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who else is building at Oran Park? 3636Feb 16, 2015 2:25 pm Crisis adverted..... $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Who else is building at Oran Park? 3637Feb 16, 2015 7:57 pm Hi Everyone. I have a question in regards to slabs. Can 32mPa be also referred to as a H class slab? I am being charged for 32mPa concrete for my slab but in other diagrams my slab is shown as a M class slab? I thought all along 32mPa was referred to a H class slab. Thanks in advance. LOVING MY FAMILY TO THE MOON & BACK!! Re: Who else is building at Oran Park? 3640Feb 17, 2015 2:55 pm The MPa is a reference to the compressive strength of the concrete to be used M & H is determined by the Soil on your site: M - Moderately reactive clay with moderate movement due to moisture. H - Highly reactive clay site with High ground movement. Basically there will be different construction required for each due to the potential for the soil to move around under and around the slab. More material required "under the surface" with H class means more cost to you A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226171 |
