Browse Forums Renovation + Home Improvement Re: Getting expert advice re: renovating 3Jan 30, 2015 9:18 pm Thanks mattb81 If anyone can recommend such builders in the Sydney hills region please let me know. Cheers Re: Getting expert advice re: renovating 4Jan 31, 2015 3:34 pm Hi Caleb, We are in North Rocks and are in the planning stages of a first floor addition and total renovation. We have had architect Brendan from BJD Design do our drawings, and will be going with Select Construction for the build. Daniel is our contact there. We have amended the plans to be within our budget and are preparing docs for DA submission. They both have facebook pages to check out. After looking at other options with other builders, we are relieved to have found this draftsman and builer, who are local too! Good luck. Re: Getting expert advice re: renovating 5Feb 01, 2015 8:26 pm Hi Parrydise Thanks for recommendations. Incidentally I'm in the same suburb as you. Just had a quick look at their websites and we will keep it in mind. Thanks all. Re: Getting expert advice re: renovating 6Mar 03, 2015 10:35 pm We used Paul from Quote: Paul's Home Maintenance & Renovations Re: Getting expert advice re: renovating 7Mar 04, 2015 11:57 am As the first step, I'm sure quite a few people would be able to offer ideas and advice if you have a photo of your floorplan you can share. My partner and I are first time renovators and we just dived straight in and so far we are thrilled with the results. Re: Getting expert advice re: renovating 8Mar 05, 2015 8:06 pm Hi there I am also in North Rocks. We are in the last few weeks of our renovation (addition and alteration). We used Envirotecture to draw up our plans and go through Council. We used Superior Constructions for the build. Can't recommend them enough. Has been an enjoyable process:-) Good luck with it all. Re: Getting expert advice re: renovating 9Mar 09, 2015 9:25 pm Hi, You need to have an idea of what you want to do before you call a builder in. A few questions to consider- Is the house big enough? Yes/ No If yes then a small reno will be sufficient (maybe move a few walls etc). If no then is there room to extend out? Going up is expensive. If it needs a major amount of extra space KDR may be better. Send me a PM if you decide on a smaller reno and want some ideas. We have done quite a few, moving a few walls, adding walls, kitchen, bathroom etc. Re: Getting expert advice re: renovating 10Mar 31, 2015 1:37 pm Hi Caleb, When you renovate your home you should consider various factors for better results. In your case you want larger kitchen, outdoor entertainment area etc. So you should give more attention to this area in order to minimize the expense. You can browse for the latest trends about home renovation and of course about the expenses too. Afterwards you can consult any home builders. My home renovation was done with the help of an in-house designer in Oakville, they had done a great job. They suggested me to take the measurement of the rooms that is to be innovated and then consider my requirements, ideas and budget. It is very important to get a good builder in order to save time and money while improving our dream home. Hi all, My concrete tile roof (pictured here: https://imgur.com/a/d2GiHJH) over the last 5 years has gotten to the point it needs a clean. Unsure why previous owner… 0 1284 What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 8060 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 16676 |
