Browse Forums Heating, Cooling & Insulation Re: Air Conditioning - Noise Reduction ? 15Jan 04, 2015 1:54 pm kassan1973 Saint Mike We have a great system - Daikin - whole house. BUT ... condenser is located near a bedroom (used by visitors - which is not all bad ... ). It can make some noise starting up - nothing bad - but as its on the wall near the window you can hear it and it can wake you up if started early morning (by me). Is there a way to cut the sound ? Like a muffler type device ? Its not bad - but when everything is dead quiet you can hear it kick in. Open to ideas. My brivis 18 kw unit has been noisy for 8 years also next to a window, i noticed when it was installed they only mounted 3 of the feet on rubber blocks it has 6 to the wall bracket so it would vibrate through the wall. So today after 8 years of meaning to fix it i installed 6 rubber blocks under each mount and 6 on top of each mount so there is no contact between ac unit mounting bolts and bracket.. And now it is super quiet even the noise from outside next to unit is alot better as its not contacting any hard surface therefore all the sound is getting dampened through the mounts. check your units mounting as this may help i used 12 car shock absorber rubbers in the mounts as they are cheap and the correct size. Regards Dean Hi Kassen1973 what you have done sounds a bit genius. Did you have a photo so I can see clearly what you done. I have an aircond near a bedroom window too,and I think I get two types of noise. One I can hear if I put my ear on the wall. I suspect this is due to the entry into the brick work isnt sealed good and the second one is coming through the window. If I could reduce it even a little it would be awesome. Re: Air Conditioning - Noise Reduction ? 16Jan 04, 2015 9:10 pm Ok will see what i can do hopefully put up on Monday 5th Jan What i used 12x Vt comm sedan or similar rear shocker rubbers from inside boot ( keep large washers as well) Mounted 1 rubber between ac unit and bracket and one on top of ac mount then used a 5/16 or 8mm bolt through the the large washer and rubbers with nyloc nuts underneath tighten bolts so as to just compress rubbers and your done. No need to add rubber underneath as there is no contact between bolt and ac unit. My compressor has 6 mounts so if yours only has 4 then 8 rubbers will do. I had a lot of noise through the brickwork and this reduced it by 90% Hope this helps and will post pics tomorrow BSTAR have PM'd you about photos Re: Air Conditioning - Noise Reduction ? 17Jan 07, 2015 2:15 pm Thanks kassen1973. I have attached the diagram of what you have suggested for someone like me that has a concrete slab instead of a wall bracket. I am going to think about this a bit more and try something. http://s1119.photobucket.com/user/arbou ... ml?filters[user]=142307334&filters[recent]=1&sort=1&o=0 Re: Air Conditioning - Noise Reduction ? 18Jan 07, 2015 11:21 pm http://i723.photobucket.com/albums/ww23 ... /AC3-1.jpg Here are some pics of what i did to cure my ac noise hopefully link works OK. Thanks Bstar i did already have a photo bucket account. Cheers Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 12709 Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 10154 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 14022 |
