Browse Forums Building A New House Re: Building with Coral Homes - Penrith NSW 2Jul 14, 2014 9:59 am Follow my Coral Daydream 28 build: https://forum.homeone.com.au/viewtopic.php?f=31&t=72384 Re: Building with Coral Homes - Penrith NSW 5Jul 16, 2014 11:07 am Follow my Coral Daydream 28 build: https://forum.homeone.com.au/viewtopic.php?f=31&t=72384 Re: Building with Coral Homes - Penrith NSW 6Jul 16, 2014 9:50 pm J&J Building our Home on The Coast. Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=55601 No longer our dream it's our reality!!! Re: Building with Coral Homes - Penrith NSW 7Jul 17, 2014 2:02 pm Building a Modified Coral Daydream 28, first build, first home and land owners. Acreage Build in Buccan, QLD. Room for the two new puppies Re: Building with Coral Homes - Penrith NSW 8Jul 18, 2014 1:41 pm Follow my Coral Daydream 28 build: https://forum.homeone.com.au/viewtopic.php?f=31&t=72384 Re: Building with Coral Homes - Penrith NSW 9Jul 18, 2014 4:38 pm Building a Modified Coral Daydream 28, first build, first home and land owners. Acreage Build in Buccan, QLD. Room for the two new puppies Re: Building with Coral Homes - Penrith NSW 11Jul 30, 2014 1:42 pm My Noosa 23 Build - viewtopic.php?f=31&t=72782 Re: Building with Coral Homes - Penrith NSW 12Jul 30, 2014 6:41 pm Hi whzzz28, I'm building a marcoola 32, with Coral Homes at Oran Park,we are just waiting for a second tender with them At the moment,should have it by weeks end. Looking at your comments you said that if you upgrade your bricks that you get free sarking and a whirlybird,is that correct? Do you have to ask for this? Which office Did you go through and who was the sales person? If correct,is sounds good! Julie Re: Building with Coral Homes - Penrith NSW 13Jul 31, 2014 1:13 pm tkwilson That does sound pretty good Charlinic6. Has anyone tried to bargain with them in regards to the cost of upgrades to the slabs from s class, which they include as standard & from what I know about the area we are looking at M class to H class slab would be required? Also did they include sarking for the roof or was that additional? We believe sarking in the roof should be a standard inclusion as it's required in all types of roofing. The reason I ask is, we just had a quote back from Coral homes & we found those prices to be pretty extreme. We were quoted for an M class slab and I found it quite reasonable. We're (still) waiting on the soil test results to confirm we only need M. Sarking was included in the quote we got from our sales guy. It was around $2000 from memory... Follow my Coral Daydream 28 build: https://forum.homeone.com.au/viewtopic.php?f=31&t=72384 Re: Building with Coral Homes - Penrith NSW 14Jul 31, 2014 3:28 pm jul33m1 Hi whzzz28, I'm building a marcoola 32, with Coral Homes at Oran Park,we are just waiting for a second tender with them At the moment,should have it by weeks end. Looking at your comments you said that if you upgrade your bricks that you get free sarking and a whirlybird,is that correct? Do you have to ask for this? Which office Did you go through and who was the sales person? If correct,is sounds good! Julie If you upgrade your roof tiles, not bricks, to Bristile classic or higher range then it should contain sarking + whirlybird as well. Just to confirm - sarking is under-roof foil layer that sits directly behind the tiles/colorbond. Sisalation sits between your bricks and wall frame and is similar to sarking (foil product) to reflect radiant heat. Sisalation is standard on Coral homes (i think it is required on all homes). The upgrade doesn't get you "Free" sarking and whirlybird, its most likely built into the price, but yes you do get them with the roof tile upgrade. Just ask your sales consultant for the price to upgrade to Bristile classic profile roof tiles. Make sure it mentions sarking on the quote (it should). Or ask them how much extra it is for roof sarking. They should be able to give you a rough price on the spot. For my 220sqm house it was around $2300 or so. You do need to ask for this, otherwise you will get the standard range of roof tiles with no whirlybird and no sarking (but doesn't cost you extra). Also confirm with your land developer as well if they have any covenant requirements for roofs. For instance Peet at Warner require flat or semi-flat roof tiles. Standard wavy roof tiles are not acceptable, thus i had to upgrade to the classic range (ended up going with Colorbond though). Good luck. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 15193 Hi so sorry for the late reply. I already contacted them and they wouldn't tell me instead they tried to get me to talk to one of their home coordinators and I'm not… 2 6680 Hi all, We are considering Enigma 46 from Mojo Homes in Gables, NSW. Has anyone built with Mojo and any pointers and feedback. Also, if anyone has built similar design… 0 13669 |
