Browse Forums Building A New House Re: Redink Yanchep, WA - First time (and Absent) build - Int 9May 27, 2014 10:01 am Yes, it is common practise in WA that the skirting boards aren't included. You can get them fitted by the people who do your floors (sometimes depending on the company and the flooring you go for) or you can get an independant skirting contractor to come in after your build to do it for you or you can just not have any at all... up to you. All the little extras that are required I would rather have done after the build is finished as you will pay less for it than through the builder. My build: viewtopic.php?f=31&t=68002 Re: Redink Yanchep, WA - First time (and Absent) build - Int 10May 27, 2014 3:15 pm Yay you started a thread! Your lot looks gorgeous. It's beautiful up that way. Obviously, we LOVE the Georgia/Alfresco floor plan as well It doesn't cost anything to move rooms around etc. It's when you have to add brickwork or change external walls that they start adding costs. Hope that makes sense. For example we moved Bed 4 to be a bit further away from the Activity room and other bedrooms. Didn't cost anything to do that. We are moving the watercloset door to be in the main bathroom and turn the small linen cupboard into a large walk in one and get rid of the "dead" space in front of the WC door. That is costing us for some brickwork and shelving, but we think it's worth it to have more storage space. We also extended the master suite .5m to help capture more breeze, that also cost money. yes, the georgia is lovely and yes, I don't think it does have skirting boards. Just to give you a rough idea of cost we were quote $1,145.46 not incl GST for 76 lineal meters of a 67mm skirting board. That was through the company that is doing our bamboo flooring. Good luck. We've got literally hundreds of things costed up between the PCQ process and now prestart just feel free to ask about costs. If I have it I'm more than happy to share. It's so helpful to know in advance of prestart so you're not totally shocked when you get your list back! Re: Redink Yanchep, WA - First time (and Absent) build - Int 11May 27, 2014 11:21 pm Posting to follow as also building with Redink & a fellow pom!! Looking forward to seeing your plan & following your journey Re: Redink Yanchep, WA - First time (and Absent) build - Int 12May 28, 2014 4:32 am Burnsfirsttime Yes, it is common practise in WA that the skirting boards aren't included. You can get them fitted by the people who do your floors (sometimes depending on the company and the flooring you go for) or you can get an independant skirting contractor to come in after your build to do it for you or you can just not have any at all... up to you. All the little extras that are required I would rather have done after the build is finished as you will pay less for it than through the builder. Thanks, Burnsfirsttime - I think I'll follow your advice and have it put in afterwards. Can't imagine not having it at all, how on earth do you not damage the paint if you clean the tiles etc! Re: Redink Yanchep, WA - First time (and Absent) build - Int 13May 28, 2014 4:39 am ardie514 Yay you started a thread! Your lot looks gorgeous. It's beautiful up that way. Obviously, we LOVE the Georgia/Alfresco floor plan as well It doesn't cost anything to move rooms around etc. It's when you have to add brickwork or change external walls that they start adding costs. Hope that makes sense. For example we moved Bed 4 to be a bit further away from the Activity room and other bedrooms. Didn't cost anything to do that. We are moving the watercloset door to be in the main bathroom and turn the small linen cupboard into a large walk in one and get rid of the "dead" space in front of the WC door. That is costing us for some brickwork and shelving, but we think it's worth it to have more storage space. We also extended the master suite .5m to help capture more breeze, that also cost money. yes, the georgia is lovely and yes, I don't think it does have skirting boards. Just to give you a rough idea of cost we were quote $1,145.46 not incl GST for 76 lineal meters of a 67mm skirting board. That was through the company that is doing our bamboo flooring. Good luck. We've got literally hundreds of things costed up between the PCQ process and now prestart just feel free to ask about costs. If I have it I'm more than happy to share. It's so helpful to know in advance of prestart so you're not totally shocked when you get your list back! Thanks, Ardie you've been very helpful You're going to think I've copied some of your design I honestly didn't! I also changed bedroom 4 and the bathrooms around - that was to use the space a bit better as I thought the long corridor was a bit of a waste of space! And took the layout of the Alfresco's bedrooms 2 and 3 for more space in the activity which was quite small in the Zenith. I think it is amazing how many of the different plans - even other builders - seem to end up similar where people are making changes to the base plans to make it more practical! I'll add the original and our 'suggested' changes in next - just need to upload it somewhere. Thanks for the pricing info for skirting boards too - that isn't too bad is it? But every little thing adds up I guess! I've been wondering about traditional skirting boards and having a row of tiles in the tiled areas rather than the usual timber skirtings. I can't help thinking tiles would work better for wet cleaning of the tiles? Not sure how 'standard' that would be though! Re: Redink Yanchep, WA - First time (and Absent) build - Int 14May 28, 2014 4:46 am Torz1980 Posting to follow as also building with Redink & a fellow pom!! Looking forward to seeing your plan & following your journey Hi Torz1980 - thank you So far we've been pretty pleased with the service from our Sales person at RedInk - he's called Anthony - he even sent 2 emails 2.5 hours ago which was pretty late in Perth! We're awaiting quote of the changes we've asked for to the original plan now! Btw I loved the basins you've chosen for your house and am looking at something top mounted too. How is RedInk about basins etc supplied from elsewhere? Randomly following a link from another thread today I found http://www.thestonesuperstore.com/ - they are apparently closing down and seems to have a few bargains! Wondering whether I could buy some basins from them or not. I think perhaps I just WANT to buy something NOW lol Re: Redink Yanchep, WA - First time (and Absent) build - Int 15May 28, 2014 5:14 am Ok here goes. This is the original plan and the changes I've very unprofessionally made to it using gimp - the garage extension isn't to scale - it is basically 1m extra to the side apart from the 1m2 to the front - would love that wall to be a feature one to match the blade wall on the other side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The back of the house was flipped around to have the living areas north facing. Please feel free to give any feedback! Any cabinets in the IT nook, over the kitchen counters and in the laundry will probably have to come afterwards. We apparently have to say window sizes now too - didn't even think about that apart from the bigger sliding doors to the alfresco! What is the awning window thing all about? Why would you want that rather than sliders? And are there any general 'rules' re where you should have them instead? We've asked for quotes for 31c ceilings throughout too so will see what they say about that. Our little home in England is very very small but it has relatively high ceilings, and it makes the place feel bigger so would love to be able to do that there too. Now I better go do some food before the OH starves to death lol - ttyl Re: Redink Yanchep, WA - First time (and Absent) build - Int 16May 28, 2014 9:29 am Personally I would pay the extra to have the 31c ceilings throughout, I don't like how pokey the 28c makes a house feel. You can get a manual roller door for the rear of the garage instead of the double doors. Check the width on the toilet next to the main bathroom - it looks very narrow between the vanity and the toilet The standard bath size here is 1500, check what your specs say and maybe increase it to 1800 and then you are utilizing that full space instead of having a little gap at the end. This isn't a very expensive upgrade. My build: viewtopic.php?f=31&t=68002 Re: Redink Yanchep, WA - First time (and Absent) build - Int 17May 28, 2014 11:17 am Hi MalSannie, thanks for starting a thread so we can share in your home building journey! I love the plan, I can definitely see some similarities to my own house. I like the theatre at the front, I wish mine could have worked like that but I didn't have the space. What's that little wall hanging off the left side of the theatre? Burnsfirsttime You can get a manual roller door for the rear of the garage instead of the double doors. I agree, a roller door would probably be far more functional and secure. Burnsfirsttime Check the width on the toilet next to the main bathroom - it looks very narrow between the vanity and the toilet The standard bath size here is 1500, check what your specs say and maybe increase it to 1800 and then you are utilizing that full space instead of having a little gap at the end. This isn't a very expensive upgrade. Without tooting my own horn too much, perhaps take a look at my plan and have a look at what I did with the shared wall between the powder room/bathroom. I extended my bath to 1700mm as BFT suggested, but I also inset the powder sink/bath wall. It's hard to explain without a pic. Anyway, I found that this solved the issue of the 'dead space' by the bath. In the future I will place shelves there for towels and other bathroom supplies. Just a thought Re: Redink Yanchep, WA - First time (and Absent) build - Int 18May 28, 2014 3:25 pm Goodluck with your.build .i am building with redink and get keys tomorrow. Had my ups and downs .but redink have been great .and pretty sad that it is all over. They are my little redink family .been in contact with them since oct2012 .so a long ride . My advice is keep in contact with them they are really.good in making you happy . Well they have for me .reading some of these other blogs about other builders I think I would of.gone nutty by now. Remember everyone has their own journey . I know we are paying them to build our homes but mistakes can happen .and I know I keep saying this ,its the way they fix it . Any guestions you have feel free to ask Re: Redink Yanchep, WA - First time (and Absent) build - Int 19May 29, 2014 5:17 pm Burnsfirsttime Personally I would pay the extra to have the 31c ceilings throughout, I don't like how pokey the 28c makes a house feel. You can get a manual roller door for the rear of the garage instead of the double doors. Check the width on the toilet next to the main bathroom - it looks very narrow between the vanity and the toilet The standard bath size here is 1500, check what your specs say and maybe increase it to 1800 and then you are utilizing that full space instead of having a little gap at the end. This isn't a very expensive upgrade. Hi Burnsfirsttime - if we can afford it we'll do it Funny you and Pan should say about the roller door - that was what I wanted but my OH thought a double door would be easier to use. My Dad, who will live in the house, might also have a problem bending to open/close a manual door - they have one in their shed now and he finds it a bit of a struggle. The changes to the WC/Bath isn't necessarily to scale so will have to see what they come back with - I've 'stolen' the WC part from their Georgia show house layout where they have a little cupboard etc. My sister took photos of it and it didn't look too narrow but I'll measure it up when we get the plans - thanks for pointing it out! Re: Redink Yanchep, WA - First time (and Absent) build - Int 20May 29, 2014 5:29 pm PanRaptor Hi MalSannie, thanks for starting a thread so we can share in your home building journey! I love the plan, I can definitely see some similarities to my own house. I like the theatre at the front, I wish mine could have worked like that but I didn't have the space. What's that little wall hanging off the left side of the theatre? Hi Pan, thanks! Yes I noticed our plans were very similar too The little wall is a blade/feature wall which was specified on the plan - but I thought if we could make it a little bit wider we could use the space behind it to hide services/bins etc. PanRaptor Without tooting my own horn too much, perhaps take a look at my plan and have a look at what I did with the shared wall between the powder room/bathroom. I extended my bath to 1700mm as BFT suggested, but I also inset the powder sink/bath wall. It's hard to explain without a pic. Anyway, I found that this solved the issue of the 'dead space' by the bath. In the future I will place shelves there for towels and other bathroom supplies. Just a thought This is the pic my sister took of the Georgia's WC so I'm hoping we could at least have it as wide as that. I like what you did to yours - will see what they come back with before I send more changes off for now - thanks for the suggestion! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 21350 4 11556 2 8052 |
