Browse Forums Owner Builder Forum Re: Owner Build in Soutern Flinders Ranges 2May 09, 2014 7:55 pm I guess the water pipe extends from near the house to a dam somewhere not all that far away ? Do you have a pumped based at that dam, or are there facilities for the fire brigade to put one of their pumpers to connect up to send the water to the house ? Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Build in Soutern Flinders Ranges 3May 09, 2014 8:16 pm There is a large SAWater dam a few km away and also a SAWater header tank. However I still need to provide a dedicated 40,000 litre steel tank (i.e. non-combustible) with CFS fittings, an engine driven pump, also fire hose reels to reach all around the house because mains water may not always be available during a major bushfire.. Re: Owner Build in Soutern Flinders Ranges 4May 09, 2014 8:43 pm It's the sort of thing that those much closer in to town never think about, because they already have a lot of things already in the ground at their front gate. I guess a concrete tank would also qualify, but a steel tank would be cheaper to bring in and install out there. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Build in Soutern Flinders Ranges 5May 10, 2014 10:57 pm Look forward to watching your progress Build thread http://tinyurl.com/llgc7yk Re: Owner Build in Soutern Flinders Ranges 6May 11, 2014 1:13 pm It's great to see how the landscape changes with the seasons. From a few scraps of dead grass to deep luscious green grass. We are looking forward to sharing in your build. Re: Owner Build in Southern Flinders Ranges 7May 12, 2014 10:38 am That is a top location! I've been through the Flinders Ranges region only once before and loved it. It sure wasn't that green back then though! Quote: I marked out the walls with Roundup (as I did not have any spray paint and there are no shops nearby). Ha. Who needs termite proofing when you mark out with a pesticide ! I look forward to seeing the rest of the build. Stewie Re: Owner Build in Southern Flinders Ranges - Wall Framing D 10May 23, 2014 9:20 pm Beetaloo More photos uploaded Love checking out the photos, but they would've been better in a new post, rather than edited in to the first post because then we have to find them. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Owner Build in Southern Flinders Ranges - Weatherboard Cladd 11May 24, 2014 4:54 pm Starting installing weatherboard cladding - 150mm Linea Scyon
I found the boards (16mm thick) difficult to cut. Saw blades were wearing out in a couple of hours. I tried both cheap blades & expensive genuine blades. They all wore out quickly. The genuine blades did last a bit longer. In desperation when I had run out of blades one weekend, I tried an old rusty +40 year old blade. It worked a treat. I was able to complete all the remaining cladding using this one blade. (Its teeth are different to the new blades. There are 2 rows of teeth) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Build in Southern Flinders Ranges - Weatherboardin 12May 24, 2014 7:04 pm 16mm thick, no wonder it was chewing through your blades so fast. Hope you were wearing a dust mask whilst chopping them up. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Build in Southern Flinders Ranges - Weatherboardin 13May 24, 2014 7:22 pm Quote: Hope you were wearing a dust mask whilst chopping them up. No, a respirator, goggles and ear muffs. New blades are designed so they don't make much dust, but this old blade did make a lot of dust. Owner Build in Southern Flinders Ranges - Weatherboards 14May 26, 2014 6:59 pm Weatherboard cladding finished. The last 4 rows of boards were the worst. I could not manage to work off my extension ladders so used used some scaffolding instead. Took me 4 hours to collect & erect the scaffolding and 10 minutes to install the last 4 boards.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Build in Southern Flinders Ranges - Weatherboardin 15May 27, 2014 12:10 pm Quote: Took me 4 hours to collect & erect the scaffolding and 10 minutes to install the last 4 boards. Maybe Beetaloo but it beats being out of action for 6 weeks with a broken leg or worse if you fall off the ladder. I know what I'd prefer ( and I bet your family feels the same way ). Stewie Owner Build in Southern Flinders Ranges - FIRE 16Jun 02, 2014 7:55 pm FIRE & FLOOD - 2 of owner builders worst nightmare.
I experienced both. At the end of January 2014 a fire was started by lightning in the Southern Flinders Rangers near Bangor. Bangor is about 60 km from my property. The Bangor fire started in largely inaccessible sparsely populated country. This fire was initially not taken seriously as there was little risk to life or property. What initially started as a small fire, flared up and continued to burn throughout February for 30 days (largely uncontrolled) until a thunder storm cooled the fire. It then continued to smoulder for another 30 days until Autumn rains finally put the fire out. The total area burnt by this fire was nearly 100,000 acres with a perimeter of 180 km. Initially I was not too worried as the fire was 10s km away from my property and there were fire breaks/control lines in position, however on day 20 of the fire there was a change in wind direction and the fire jumped containment lines. At this stage my house was undefendable. The house was not yet protected from ember attack. Roof flashings were not installed, external doors were not installed, ember screens to windows were not installed, ceilings and wall lining were not installed (to protect roof trusses and timber stud walls). Water was not connected, nor was fire fighting equipment (tanks & fire pumps not yet installed). On day 20 of the fire, I was working on the house when there was a change in wind direction and I saw smoke building up and moving directly towards me. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As the house could not be protected, I stopped what I was doing & jumped in my car & fled. Once I was clear of the immediate fire threat, I stopped and took this photo: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My house is somewhere behind all that smoke! I spent the night in a neighbouring town. This photo was taken by a photographer later that night looking towards my property. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I returned the next morning to check on my property & put away my tools (as I had left in a hurry). The fire approached on 2 sides and came to within 800m. In both cases a sudden change in wind direction pushed the fire away. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Build in Southern Flinders Ranges - FIRE! 17Jun 02, 2014 10:27 pm Jiminy ! At least you were sensible and left at the appropriate time and didn't leave it to too late as a lot of people do. It makes you realise what all the new CFS rules are for. Stewie Re: Owner Build in Southern Flinders Ranges - FIRE! 20Jun 03, 2014 10:02 pm Bushfire dramas aside, I can't believe how quick you are and in such a remote spot! Are you doing this on your own? Congratulations! Nice to put that to bed before christmas, now you can relax 3 7796 0 6182 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 18561 |
