http://mattandalexbuild.blogspot.com.au/
Congrats Ally007, following your blog.
Browse Forums Building A New House Re: Porter Davis homes 9131Feb 16, 2014 11:31 pm That's funny, it sounds like the cleaning crews are quite different from house to house. Our place was filthy after handover, so we spent two days cleaning. Our move was booked for two days after handover so it was one tiring race! A few cleaning challenges for us included... - filthy toilets (at a glance during inspection they looked OK but they'd clearly seen some use as ashtrays as well as the usual when we looked more closely) - huge amounts of plaster dust (especially in the cupboards and carpet) - filthy baths and basins (especially the spa - we are still getting dust and grime out of the pump at times) - windows were covered in dirt, but in a new estate this is to be expected - stickers hiding on things (sinks, baths, toilets, alfresco support pillars, you name it) - paint splatters (small ones are almost impossible to see during handover but we are still finding them three months after handover) - stray silicon sealant splattered around the place (invisible until it gets dirty) - rubbish and debris around the yard - more plaster dust One thing we did do though is insist on the cleaners returning to sort out things that were just too much trouble for us. Things like stickers and labels left on things, which left sticky residue. We have also had the maintenance guys out to remove paint from window frames and the like. Strangely enough the maintenance people have been pretty good about this sort of thing. Much more helpful than my BC or SS. I'd definitely suggest putting two full days aside to clean though. Maybe more for a two storey. HD Re: Porter Davis homes 9132Feb 17, 2014 9:59 am hmmm cleaning does sound like it varies. I was fine cleaning things, mostly. But the window runner are just too difficult for me to clean. And they are seriously disgusting. i'm just glad we weren't moving in straight away, its given me some time to get things sorted Re: Porter Davis homes 9133Feb 17, 2014 3:12 pm mirzYay! we finally started so I also started a blog... will try and put it in my signature... until then... http://mattandalexbuild.blogspot.com.au/ Congrats Ally007, following your blog. Thanks Mirz! Maybe I should write which house we are building lol Re: Porter Davis homes 9134Feb 17, 2014 3:26 pm tlblhaywardCan anyone help me to understand the options for downlight wattage? Is there a "standard" wattage? Are there different beam angles or do PD only have a single option? Help please!!! I'm interested in this information as well. What I've been able to work out is that PD use Clipsal Downlights. But no information about lumens, wattage, beam angles, etc. Hi Bramsy, I had downlights installed for my build and I managed to find the boxes for the downlight housing and the globe inside. Details are as follows: - LED housing kit is called "301 LED GU 10 Downligh" and the brand is 'Telbix' - The height of the heat can with the transformer mounted is 155mm and the hole cutout diameter is 70mm - The housing kit is made of aluminium - The globes provided branded as 'PHL' and are 9w GU10 globes - The lumens of the globe are 520lm for the 3000k or 550lm for the 5500k - The globes have a GU10 base, have a 60 degree beam angle and the dimensions are 50mm diameter and 85mm length Re: Porter Davis homes 9135Feb 17, 2014 5:36 pm Here is exactly what I got from PD's electrical department via email... LED CLASSIC - First entry level LED Colour: White & Brushed Chrome (additional charge) Globe: 9 watts LED with anti glare lens Lumens: 520lm Size: 72mm D Lifespan: approx 30,000h Beam angle: 60% Other: GU10 B-9 240 volts Non-dimmable LED ADVANCED DIMMABLE - Second entry level LED Colour: White & Brushed Chrome (additional charge) Globe: 6 watts LED Lumens: 540lm Size: 72mm D Lifespan: approx 40,000h Beam angle: 60% Other: Trailing edge LED driver Dimmable: Range 10-100% Re: Porter Davis homes 9136Feb 17, 2014 7:49 pm Hey folks... has anyone had PD put a fireplace in? Just after an estimate of cost. Re: Porter Davis homes 9138Feb 17, 2014 9:21 pm tlblhaywardHey folks... has anyone had PD put a fireplace in? Just after an estimate of cost. Hi T I been quote for 12k for the same one as Waldorf display We received the same information. We decided to include the fireplace provision (around 2ks) and do a fireplace post handover. Sweet-home100 Waldorf 44 - Knock Down & Rebuild project - Coniston Facade - Rear Alfresco - Master Bedroom option Shower to Powder Option - Enclosed Rear Corner Option Re: Porter Davis homes 9139Feb 17, 2014 11:13 pm tlblhaywardCan anyone help me to understand the options for downlight wattage? Is there a "standard" wattage? Are there different beam angles or do PD only have a single option? Help please!!! I'm interested in this information as well. What I've been able to work out is that PD use Clipsal Downlights. But no information about lumens, wattage, beam angles, etc. Hi Bramsy, I had downlights installed for my build and I managed to find the boxes for the downlight housing and the globe inside. Details are as follows: - LED housing kit is called "301 LED GU 10 Downligh" and the brand is 'Telbix' - The height of the heat can with the transformer mounted is 155mm and the hole cutout diameter is 70mm - The housing kit is made of aluminium - The globes provided branded as 'PHL' and are 9w GU10 globes - The lumens of the globe are 520lm for the 3000k or 550lm for the 5500k - The globes have a GU10 base, have a 60 degree beam angle and the dimensions are 50mm diameter and 85mm length Thanks. Just checked online. The LEDs are like $45 each. The 50w downlights are around 900 lumens. We might have to replace it afterwards with something like the brightgreen or even the ledified globes. Re: Porter Davis homes 9140Feb 18, 2014 1:47 pm Thanks. Just checked online. The LEDs are like $45 each. The 50w downlights are around 900 lumens. We might have to replace it afterwards with something like the brightgreen or even the ledified globes. Just a couple of quick points as well about the downlights: - 550 lumens is really not very bright and the beam angle is very narrow, it is disappointing that PD can't offer better LED downlights given the price point that they are charging. - The downlights PD provide are 70mm so its quite annoying if you're looking to do a quick swap over to newer/brighter downlights down the track as most are usually 90mm - When PD installs the downlights, they unfortunately hardwire the downlights. These days you can buy replacement downlights that come with a normal plug and all you need to do is plug it into a socket and that's it! This means that you wouldn't need to have an electrician perform the work. I'm actually in the process of changing over some of the downlights and also installing downlights upstairs - I've received quotes for $75 an hour (+ GST) from electricians and they reckon they can do 8-10 downlights per hour. Might be something to keep in mind as an alternative. check out the facebook page Building with Better Built - it helps! But i've heard both builders are fantastic. 1 160075 Yeah, that’s fair to be uneasy about it. We had similar wording pop up early on and our conveyancer pushed back hard. A few things were amended once we queried it,… 3 2640 Hi paul smith, Did you go ahead with Dezire Homes? I am in the market now and was looking for some feedback? Thanks 4 176470 |
