Browse Forums Kitchen Corner Re: Stain on caesarstone 26Jun 11, 2012 8:22 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Stain on caesarstone 29Oct 17, 2013 3:13 am Read on another post that someone has successfully used the magic eraser sponges and the caesarstone cleaner to remove red wine and turmeric stains from her essastone white bench tops, no marks left and gloss intact Building in Myalup with Redink PCQ : Nov 2012 Prestart: 17 th March 2013 Builders Permit: Sept 2013 Completed build Aug 2014 viewtopic.php?f=31&t=67559 Re: Stain on caesarstone 30Mar 23, 2018 7:47 am Read the Care & Cleaning Essentials for Stone https://stonebenchtopcleaner.com.au/sds/Quartz_Care&Maintanence_Essentials_(2018web)DSA_Rev4.pdf Aaron Master Stonemason <!-- w --><a class="postlink" href="http://www.stonebenchtopcleaner.com.au">www.stonebenchtopcleaner.com.au</a><!-- w --> Re: Stain on caesarstone 31Mar 24, 2018 8:31 pm Got uba tuba granite and professional cleaners told me to use high quality dish washing detergent on a microfibre cloth that is wrapped around a cleaning tool, make sure cloth is fairly wet and place dishwashing liquid along bottom of cloth, wipe bench all over and sqee gee off and finish wiping last bits of water with a large microfibre cloth, done this for years and bench sparkles clean with high gloss shiny look. Re: Stain on caesarstone 32Mar 24, 2018 9:27 pm Thats fine, but you are talking about a granite, not quartz Also soap or detergents will make the surface dull and sticky over time. Professional cleaners are not stonemasons, we see all the time oven, drain cleaner damage and also damage from gumption on all stone from professsional cleaners including bleach Aaron Master Stonemason <!-- w --><a class="postlink" href="http://www.stonebenchtopcleaner.com.au">www.stonebenchtopcleaner.com.au</a><!-- w --> Re: Stain on caesarstone 33Mar 25, 2018 10:13 am Aaron Master Stonemason <!-- w --><a class="postlink" href="http://www.stonebenchtopcleaner.com.au">www.stonebenchtopcleaner.com.au</a><!-- w --> Re: Stain on caesarstone 34Apr 05, 2018 8:58 am StoneGuru Thats fine, but you are talking about a granite, not quartz Also soap or detergents will make the surface dull and sticky over time. Professional cleaners are not stonemasons, we see all the time oven, drain cleaner damage and also damage from gumption on all stone from professsional cleaners including bleach Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7437 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 4118 |
