Browse Forums Safer Living Re: Did you leave your garage door open? 4Oct 12, 2013 11:27 am Did I leave a tap on, leave the dog inside, put the garbage out, turn on the alarm ? Invent a smartphone app for that maximus and you will be a millionaire. Stewie Re: Did you leave your garage door open? 5Jan 05, 2014 10:39 pm I was under the impression this sort of stuff was exactly why they have the smart home's(and home server softwares) with all it's sensors? Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Did you leave your garage door open? 6Jan 06, 2014 10:50 am Quote: I was under the impression this sort of stuff was exactly why they have the smart home's(and home server softwares) with all it's sensors? Some of them are very good but cost a fortune. Others are not so good and are obviously cheaper but leave a lot to be desired when it comes to integration etc. I've yet to come across one package that does it all, doesn't cost an arm and a leg in installation and ongoing costs nor require someone with a PhD to rectify problems. Stewie Re: Did you leave your garage door open? 7Jan 06, 2014 11:07 am I'm told Z-wave is very good... http://www.smarthome.com.au/9-z-wave Appendium, one of the things I'm still waiting to come online is some Z-wave modules like this http://www.zwaveproducts.com/Zwave-Lighting/Zwave-Wall-Receptacles.html but for the Australian market so it looks identical to to a normal outlet with maybe just a LED for status. anyway given enough time I think we'll get these sorts of things and all will be sweet Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Did you leave your garage door open? 8Nov 13, 2014 4:47 pm I'd love to try this out. Thanks for the idea! Re: Did you leave your garage door open? 9Jan 05, 2017 3:55 pm Z-Wave user here with garage door sensor. I can testify this work well. You need a controller hub ($200+), plus a sensor ($60+) to get started. You can add stuff like light and socket controls etc and control it all from the interweb Beware though, you need to get your z-wave gear locally because the frequencies they use in EU/US are different. There are loads of AU suppliers (I recommend CapitalSmartHomes- I'm not affiliated with them, but they've just given me good service compared to others) Re: Did you leave your garage door open? 11Sep 26, 2017 11:10 am Security systems have made lives quite easy now. You can check the garage door from your smart phone. Open/close it from mobile.You can check the lights, check if you left the iron on, keep a check on your kids while they are at home and you in office. All security systems are now pet friendly so pets are also not a problem Re: Did you leave your garage door open? 12Apr 15, 2020 4:46 pm I don't need to worry because my smart locks work well Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3890 Hello! We have a very large open plan living room and wanted to get layout options, and furnishing ideas for this space. Currently there is only a… 0 10739 My open shelf pantry will be similar to below image with window. all appliances like rise cooker, dish washer will be in the… 0 1242 |
