Browse Forums Windows & Doors Re: Low E glass - are you using it, pros and cons 3Aug 17, 2013 9:37 am Miglas High Performance Composite Double Glazed Windows Phone 1300 MIGLAS Fax (03) 9728 3555 http://www.miglas.com.au Re: Low E glass - are you using it, pros and cons 12Sep 25, 2013 6:57 pm Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Low E glass - are you using it, pros and cons 16Sep 30, 2013 9:31 pm Sure, Viridian, that's all good and fair, but if a customer had a solar gain issue, ideally they would utilise an outside form of shading eg roof/awning/trees/neighbouring property etc; for it is also true that ANY OUTSIDE FORM OF SHADING WILL PERFORM MUCH BETTER THAN ANY GLASS TREATMENT, won't you agree? A bit of strategic planning goes a long way when it comes to windows... By the way, we love your Pyroguard 40 product, our windows are BAL40 compliant when used in conjunction with Pyroguard 40! Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Low E glass - are you using it, pros and cons 17Oct 01, 2013 8:52 am Windowfactory Sure, Viridian, that's all good and fair, but if a customer had a solar gain issue, ideally they would utilise an outside form of shading eg roof/awning/trees/neighbouring property etc; for it is also true that ANY OUTSIDE FORM OF SHADING WILL PERFORM MUCH BETTER THAN ANY GLASS TREATMENT, won't you agree? A bit of strategic planning goes a long way when it comes to windows... By the way, we love your Pyroguard 40 product, our windows are BAL40 compliant when used in conjunction with Pyroguard 40! Totally agree. Stopping heat from getting into the building is best. External shading/eaves/shade devices, etc all help. Re: Low E glass - are you using it, pros and cons 18Oct 21, 2013 11:27 pm Thank you for the information. It certainly gives food for though and has given me some points to think over. We have been told that we need to get a 6 star energy rating and to do that we have been presented with four options, one is to use low e glass and increase insulation. It bugs me that we are told this now and it wasn't allowed for in the quote we got but building seems to be a minefiled of extra costs. It sounds like DG is the go, not sure we can afford it but I also don't know how it compares price wise. Is it worth putting DG on the main large living areas but not applying it to all windows? I am taking on the point that preventing sun from entering is a major factor and we intend to do this by having our alfresco area extended to provide more shade. It seems that taking the alfresco off was a suggestion on how to meet the 6 star rating so that confuses me more. I will have to speak with the guy about this. We are building in Adelaide Hills so we have the extremes of hot weather in the summer but cooler weather in the winter. The temps range from 42 to -2. Re: Low E glass - are you using it, pros and cons 19Oct 22, 2013 5:06 am hills_kiwi Thank you for the information. It certainly gives food for though and has given me some points to think over. We have been told that we need to get a 6 star energy rating and to do that we have been presented with four options, one is to use low e glass and increase insulation. It bugs me that we are told this now and it wasn't allowed for in the quote we got but building seems to be a minefiled of extra costs. It sounds like DG is the go, not sure we can afford it but I also don't know how it compares price wise. Is it worth putting DG on the main large living areas but not applying it to all windows? I am taking on the point that preventing sun from entering is a major factor and we intend to do this by having our alfresco area extended to provide more shade. It seems that taking the alfresco off was a suggestion on how to meet the 6 star rating so that confuses me more. I will have to speak with the guy about this. We are building in Adelaide Hills so we have the extremes of hot weather in the summer but cooler weather in the winter. The temps range from 42 to -2. To reduce solar heat gain, best option as mentioned, is shade the window, second best is to use low-E, IMO only in double glazing. Double glazing on it's own has no effect on solar heat gain. In single glazing low-E can suffer from thermal shock, and is difficult to maintain. Plus if you use double glazing it will help with the -2 temperatures. Double glazing in one area will aid the conservation of heat inside the home, it won't help solar heat gain. I would say that you live in a primarily heating area in the energy rating software, and taking the alfresco off aided the heating component at the expense of cooling. It's based on averages and statistics, so, like the man with one leg encased in ice and one in boiling water, on average he was comfortable. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low E glass - are you using it, pros and cons 20Oct 22, 2013 7:55 am ed @ ecoclassic To reduce solar heat gain, best option as mentioned, is shade the window, second best is to use low-E, IMO only in double glazing. Double glazing on it's own has no effect on solar heat gain. In single glazing low-E can suffer from thermal shock, and is difficult to maintain. Plus if you use double glazing it will help with the -2 temperatures. Double glazing in one area will aid the conservation of heat inside the home, it won't help solar heat gain. I would say that you live in a primarily heating area in the energy rating software, and taking the alfresco off aided the heating component at the expense of cooling. It's based on averages and statistics, so, like the man with one leg encased in ice and one in boiling water, on average he was comfortable. Ed Agree with Ed. If you are trying to reduce the direct sun passing through glass by using tint/colour, thermal stress is created due to heat build up or temperature differences across the glass. Tinted glass may need to be toughened to resist thermal breakage. You should have your glazier do a thermal assessment of the windows. This generally applies to both single and double glazing. Low-E coatings will increase the thermal stress on tinted glass too. In Hills_kiwi's case with that temperature range, I'd also recommend double glazing with Low-E where you can afford it and single glazed Low-E where you are in budget mode! 0 2355 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17977 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 14528 |
