Browse Forums General Discussion 1 Sep 23, 2013 5:38 pm Hi, I'm looking to either demolish this block wall balustrade and start from scratch OR fix it up. Its only 600mm high, so from my research it needs to be 1000mm high? Money is tight, so i'd like to get some opinions on how to add 400mm to this existing wall and fix it up a little. The wall is old, needs to be reinforced in a couple of spots, apart from that its in OK shape. I've priced up all new glass, wire ballustrade, Timer, steel, Stainless mesh panels for vines to grow through etc etc. and nothing is going to be cheap doing 36m of any type. Just wondering if anyone else had some ideas for a restoration/renovation of this wall OR a more cost effective new compliant balustrade? Cheers http://www.realestate.com.au/property-house-nsw-gymea+bay-113431567 Re: Bessa Block balustrade restoration HELP! 2Sep 24, 2013 8:15 pm Those type of walls are dangerous as a balustrade and not worth keeping or repairing. There is no reinforcing in them and they rely solely on the bond of the sand/cement mortar to hold them all together. Once you have a small crack in one of the blocks or the mortar the whole wall is compromised. Stewie Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3625 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 12036 Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 34413 |
