Browse Forums Home Theatre & Automation Re: Pre Laying Cabling Questions for Theatre 3Sep 20, 2008 1:00 am Wow they do look nice. A little expensive though I must say
I like the idea of also having a plate behind the tv with hdmi and component, but I'm not sure I'd beable to feed them throught a 35mm conduit, for example the hdmi connector is quite wide, would that fit down a 35 mm conduit, and then surely they'd be no room left for the three component connectors..... Lloyd Re: Pre Laying Cabling Questions for Theatre 4Sep 22, 2008 12:12 pm You could also try:
http://www.selbyacoustics.com.au They have a complete range of cables and home theatre equipment and they deliver!! Re: Pre Laying Cabling Questions for Theatre 6Sep 22, 2008 10:58 pm lloydmav they are seriously sleek wall plates!! ...and well priced!! Re: Pre Laying Cabling Questions for Theatre 8Sep 23, 2008 1:24 pm they do!
But why would you want to use RCA plugs when there are proper speaker wallplates? Re: Pre Laying Cabling Questions for Theatre 9Sep 23, 2008 2:03 pm probably because I don't have a clue what I'm doing
So would using a wallplate which excepts a banana plug be better than a wallplate that excepts an RCA connection? Although its all new to me, I'd like to learn how to do it all. The wallplates I have left over from bunnings are just rca red and black connections. And at the back of the plates I have to solder the spreaker wire to attach. Would be good if there was a good quality way to attach without soldering aswell. Thats more of a pain to do on site Lloyd Re: Pre Laying Cabling Questions for Theatre 10Sep 23, 2008 4:03 pm These are the go:
http://www.selbyacoustics.com.au/storef ... i=31768116 These are screw terminals to put the wire in back and front or you can use banana plugs: http://www.selbyacoustics.com.au/storef ... i=30879676 Re: Pre Laying Cabling Questions for Theatre 11Sep 23, 2008 7:36 pm thanks Matt. your a legend
How important is the quality of these connections also the quality of the speaker cable? The room dimensions are about 5 by 4 metres. Not sure how good the speaker cable I have is, I was given it, the reel says High Performance Figure 8 O.F.C Speaker Cable, 60/0.12mm W-2013 I was intending to run this stuff through the walls and also make the leads from amp to wall and wall to speakers out of it. Is this good enough? I don't want to destroy the quality of the sound especially if I find a really nice speaker setup Lloyd Re: Pre Laying Cabling Questions for Theatre 12Sep 23, 2008 7:55 pm lloydmav Not sure how good the speaker cable I have is, I was given it, the reel says High Performance Figure 8 O.F.C Speaker Cable, 60/0.12mm W-2013 I was intending to run this stuff through the walls and also make the leads from amp to wall and wall to speakers out of it. Is this good enough? I don't want to destroy the quality of the sound especially if I find a really nice speaker setup That is (should be) 16 awg speaker cable which is good for up to 15 metres without too much line loss. It will be fine in the average theatre room!! I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2717 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4944 As above, you will need to trim your sheet to land on the joist, also make sure you are running your length at right angles to the joists 2 1810 |
