Browse Forums Building A New House Re: Building in Aveley, Dale Alcock - bevnic's build thread! 2Aug 28, 2013 10:16 pm I'd actually use two glass doors leading into the games room, but I like the benefit of closing off noise while maintaining as much light as possible. And I like glass doors! White painted French doors would look great. Do you expect to have high traffic past your hallway entrance? We didn't close of our hallways. We don't have kidlets (yet) but I can already see the benefit of being able to section off the minor bedrooms from the rest of the house, particularly in regards to noise, cooling/heating etc. Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 3Aug 28, 2013 10:30 pm Looking good! I would put doors, or at least the brickwork to be bale to add a frame and door later everywhere you might want to put them. But also consider light switch position if you are going to add the doors later. A hinged door could swing 180 degrees so doesn't block the hallway, that's what they did with our garage door into the house. For the WIP door are you doing a standard door? I've seen someone else put a door with frosted glass which makes it look a bit special The one suggestion I make to everyone is chamber the laundry sliding door into a fixed door. You can then either add a window or have a door with glass. Less cleaning and I do think it looks neater, don't have to worry about blinds! It's one of the small things I'd done! Re: Building in Aveley, Dale Alcock - bevnic's build thread! 4Aug 28, 2013 11:03 pm Thanks fancy pants & fmac! Fmac, I'm with you on the pantry door, it's an absolute must! My only complication with games room doors is that I really wanted the TV in the middle of that wall. That's where French doors would look best. So maybe a small set of doors on one side? I just love symmetry & that throws me out slightly - I am on the fussy side! Re: Building in Aveley, Dale Alcock - bevnic's build thread! 5Aug 28, 2013 11:08 pm I have a friend with a theatre and a door on either side like your games room. They have a glass door on either side. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 6Aug 29, 2013 4:55 pm I'd put a french door on either side - pretty AND symmetrical! Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 7Aug 29, 2013 9:49 pm I'm leaving the games room door decision for a little while longer but definitely putting in a sliding hallway door. It will match my pantry door! So many decisions to make, thank goodness for this forum. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 8Aug 29, 2013 10:46 pm I'd also move the WC door as far forward as it will go. You can never have too much space, so many these days require a gymnastics act to get in and shut the door Re: Building in Aveley, Dale Alcock - bevnic's build thread! 9Aug 30, 2013 5:11 pm Hey Bevnic! So exciting to see more Vale builders starting up forums Where abouts is your land? Cameron & Kelly The Vale in Aveley, WA Homebuyers Centre The Regent Our Home Thread: viewtopic.php?f=31&t=65879 Re: Building in Aveley, Dale Alcock - bevnic's build thread! 10Aug 30, 2013 5:21 pm Another Aveley builder, certainly a popular area at the moment which is completely understandable Welcome to the forum and I look forward to following your build. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 11Aug 30, 2013 5:41 pm kellyt1992 Hey Bevnic! So exciting to see more Vale builders starting up forums Where abouts is your land? Our block is on Limone street, at the park end. It's still a giant sandpit, I can't wait for there to be an actual street there. itzeddie Another Aveley builder, certainly a popular area at the moment which is completely understandable Welcome to the forum and I look forward to following your build. We fell in love with the estate the first time we drove in. We wanted somewhere peaceful with lots of open space & places to walk. Hopefully the area is just what we are after! We have lived 600km from Perth for 8 years & are moving back next year. Perth has got so much bigger & busier since we left. Re: Building in Aveley, Dale Alcock - bevnic's build thread! 12Aug 31, 2013 9:35 am Hi Bevnic Looking forward to progress photos also ) Re: Building in Aveley, Dale Alcock - bevnic's build thread! 13Sep 02, 2013 10:09 pm Good to see you have started your own thread. I would use glass doors to close off the hallway and games. Gives you that option to close off the noise but still makes it feel quite open. All our living room internal doors are glass. Not sure how I'm going to keep them all clean but ill worry about that later. And as fmac suggested, I would change the laundry door to a hinged rather than sliding. We did that and I don't think it was a cost difference. Will be a lot easier to keep clean. My only advice is to be patient, the next few months nothing much happens. Spend some time at da central when u are in town to prepare for prestart. My build thread: viewtopic.php?f=31&t=64437 Re: Building in Aveley, Dale Alcock - Exterior Colours 14Sep 12, 2013 8:30 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our first big decision since signing up is deciding on our exterior colours. Roof: Monier Horizon Tiles in Barramundi Bricks: Austral C0llier Front Render: Solver vitesse 150% Portico Render: Limestone Garage: Caoba Window Frames: Charcol Lustre Feeling good about these decisions! Will still have a while before pre-start but I have flooring decisions ticking over in my head. I'm heading to some displays this weekend so hopefully I'm clearer after that. Re: Building in Aveley, Dale Alcock - Exterior Colours 15Sep 12, 2013 8:46 pm Love your choices. They'll look great together. Sometimes I think we'll be the only house in Vale that is completely rendered! Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Building in Aveley, Dale Alcock - Exterior Colours 16Sep 15, 2013 8:02 pm Thanks fancy pants! At least you are unique! I just love the bricks, it might have something to do with currently living in a fibro house. I can't wait for a visit to Vale this weekend and see how our sandpit is looking. Plus research for pre-start & debating tiles vs wood floors! How do people make all these huge decisions?! Re: Building in Aveley, Dale Alcock - Exterior Colours 17Sep 15, 2013 8:21 pm Love the colours! Our flooring decision was based on what is easier to change! And I'm not a fan of tiles, as beautiful as they are I just think they can be very cold in winter! Also we went with a white kitchen and if we'd had tiles I have a feeling our house would have looked a little clinical! The wood look flooring gives it some warmth Good luck! So many things to decide on!! Re: Building in Aveley, Dale Alcock - Exterior Colours 18Sep 16, 2013 7:45 am Did you scan the plans or did you receive electronic copies? Will try and scan ours to post Re: Building in Aveley, Dale Alcock - Exterior Colours 19Sep 16, 2013 11:26 am Redstorm Did you scan the plans or did you receive electronic copies? Will try and scan ours to post Redstorm, you can ask your CLO to send you an electronic copy of all your plans. That's what we did. It means we can email whatever plan is relevant in order to get an accurate quote for something (flooring, skirting boards, window treatments, liquid limestone etc.) It makes everything so much easier! Building with Dale Alcock Homes in Aveley Our thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=63880 And yes, my pants are indeed fancy. Re: Building in Aveley, Dale Alcock - Exterior Colours 20Sep 16, 2013 6:47 pm Yes Redstorm, these plans came from our sales rep. It is useful to have them electronically. Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3507 Hello, I am currently working on a study in regards to building contracts in Australia. I would like to interview people with their building experience in Australia and… 0 1413 |
