Browse Forums What's New Re: Karndean looselay vinyl planks - any good? 55Aug 07, 2013 10:51 pm The link above says 'ARDEX Feather Finish™ is formulated to efficiently smooth surfaces by filling imperfectionsm Will speak to flooring people but he kept talking about floor being flat etc so maybe it's screed and feather finish isn't even what he is talking bout haha. It does say screed on my card Re: Karndean looselay vinyl planks - any good? 56Aug 08, 2013 11:40 am l have no issues with my floor(level/rough)finish,l knew before slab was poured that l was having vinyl planks,builder made sure tradies were careful not to chip concrete.lmo you need to make sure installers have laid planks before. Re: Karndean looselay vinyl planks - any good? 57Aug 08, 2013 12:28 pm I'm thinking the feather finish might help with slight imperfections and nicks but the leveling compound is what you need if your slab is uneven, which makes sense. The feather us probably a thin coat to smooth it out but not actually make the slab completely flat. HD Re: Karndean looselay vinyl planks - any good? 58Aug 08, 2013 3:11 pm pattycake4 l have no issues with my floor(level/rough)finish,l knew before slab was poured that l was having vinyl planks,builder made sure tradies were careful not to chip concrete.lmo you need to make sure installers have laid planks before. We knew about planks prior to building and we had also booked an experienced installer way in advance but things don't always go according to plan I'm afraid Re: Karndean looselay vinyl planks - any good? 59Aug 08, 2013 3:26 pm Our builders are aware of vinyl too as we have notes to adjust screed in wet areas for smooth transition. Slab isn't 100% flat though going by slight puddles as rain dries up Re: Karndean looselay vinyl planks - any good? 60Aug 08, 2013 4:52 pm If you have documentation to back your case,then builder should rectify. Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8878 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15635 |
