Browse Forums Kitchen Corner Re: Plumbing behind fridge - affect the depth? 27Jul 27, 2013 2:21 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Plumbing behind fridge - affect the depth? 28Jul 29, 2013 3:55 pm rogerinaus Just to give you something else to mull over. If putting the shut off behind the fridge should never be done, and only put in a cabinet. Can you tell me where the shut off went in YoullNeverWalkAlone's kitchen? I'm guessing you would have put it in the open space behind the books. Thanks Roger, this is pretty much the same layout to our kitchen except the island runs the other way, with the fridge facing the end panel. We have no surrounding cupboards, and like this photo, we have a walk in pantry to one side (with only one door). At the end of the day, it is how it is, I'm not about to rip our kitchen apart for the sake of a tap which is already there. I was merely trying to find out how much others' fridges protrude that have plumbed ice/water. I would be interested to know how much the above fridge is sticking out because it looks fine to me. If it's in the same vicinity as the one we are looking at I would happily buy it. Thanks Kexkez for keeping the thread on topic. Second Time 'Round Re: Plumbing behind fridge - affect the depth? 29Jul 29, 2013 7:13 pm It's pretty easy to work out Ray. If your current depth of cupboards are 705mm with a tap behind that sticks out 55mm that leaves you 650mm then just suss out the fridge you want to buy. Look at the specs and compare. Whatever the difference will be how much your fridge sticks out. Look at how the doors pivot too. Most open out past the side of the fridges about 20-30mm. For this reason the back of the fridge doors should be parallel or slightly in front of the adjoining cupboard doors depending on how much space you have left either side for the appliance ventilation. As you say, it is how it is and unless you decide to spend a fair few dollars to re-position the tap you may well end up with your fridge doors sticking out 150mm but that depends a lot on whichever fridge you choose. Stewie Re: Plumbing behind fridge - affect the depth? 30Jul 29, 2013 7:54 pm the builders pumper for our place accidentally gave us a tap point behind our double fridge space as well. It's capped ( no tap) It was a mistake and it was decided that it was far less exxy to leave it than to rip it out. We nicely opted to say we'd keep it rather than insist they remove it. Our fridge does stick out but then you are meant to have some space behind a fridge anyway. We have a door way on one side and stove and stove cupboards to the other side with single brick walls defining the walls of the fridge cavity. Love the above fridge cupboards that seem the norm over east. Here they are a fancy, upmarket addition and certainly not standard. Wish we had one. Re: Plumbing behind fridge - affect the depth? 31Jul 30, 2013 5:14 am Our fridge space is 740 deep and the cabinet is 712, but the door and handles take it to 915, so it sticks out heaps but we’ve learnt to live with it. From the fridge handles to the bench is 980mm but it’s a huge gap and you could cope with less space. This is also our entry to the kitchen and we have never had any issues. Ray, your kitchen / pantry / dining area sounds the same as ours, this shot shows how it looks. http://i1055.photobucket.com/albums/s507/grumblebum54/fridge1_zpsa56c0de6.jpg Regards, Grumbles Re: Plumbing behind fridge - affect the depth? 32Jul 31, 2013 12:47 pm Thanks Grumblebum. Our kitchen is very similar. Judging by what another member PMd me and your responses here I think 10-15cm outside of the fridge space seems the norm considering the door depth and handles need to be outside the space. Logically then the more bulky the door and handles are the more it will stick out. Like others have said, I'm sure it will probably look a bit odd sticking out for the first few weeks (as our current fridge is small enough to fit well inside the space in both width and depth), but over time it will just become normal. I really appreciate those who took the time to reply. Second Time 'Round Re: Plumbing behind fridge - affect the depth? 33Jul 31, 2013 2:34 pm In grumblebums photo most plumbers would put the tap in the single door cabinet beside the drawers. Normally the carcass of the fridge sits level with the cabinets and only the thickness of the door protrudes. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Plumbing behind fridge - affect the depth? 34Aug 06, 2013 5:16 pm I had in my last place as per what a few of the guys mentioned here.. the tap was placed in the cupboard beside the fridge recess and plumbed through with a small hole. This will give you an idea. Perhaps see if you can get the tap moved slightly? Re: Plumbing behind fridge - affect the depth? 35Aug 13, 2013 11:05 pm On a totally unrelated note to the plumbing, reading this thread and going through our design, we're probably not going to have water to the fridge (we like the fridge / freezer pigeon-pair setup) but I've realised that as we're having a pantry next to the cavity, I'll put the power-points in there with a "desk-grommet" in the cupboard wall separating them ! Thanks guys, P_D http://www.4cabling.com.au/desk-grommet ... -2184.html http://www.jaycar.com.au/productView.asp?ID=HP1228 . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plumbing behind fridge - affect the depth? 37Aug 14, 2013 4:19 pm After reading this thread and getting all prepared for various options for our fridge water tap our builder said "oh we put all fridge water taps in a little alcove/niche in the wall behind the fridge space so it doesn't take up any space in the cavity". How nice is that?! Sensible builders?! Build thread: viewtopic.php?f=31&t=65085 Re: Plumbing behind fridge - affect the depth? 38Aug 14, 2013 4:36 pm EmyN .....in a little alcove/niche in the wall behind the fridge space so it doesn't take up any space in the cavity". How nice is that?! Sensible builders?! From reading this thread, yes nice, but possibly more sensible if it was (in a alcove / niche) in the cupboard next to the fridge ? P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plumbing behind fridge - affect the depth? 39Aug 14, 2013 4:57 pm Haha PD do you like stirring?? Meh, I can live with having to move my fridge in the rare instance of a plumbing problem occuring. Build thread: viewtopic.php?f=31&t=65085 Re: Plumbing behind fridge - affect the depth? 40Aug 15, 2013 1:10 pm EmyN Haha PD do you like stirring?? Meh, I can live with having to move my fridge in the rare instance of a plumbing problem occuring. Oh sorry, Not stirring at all EmyN !! As I said, we're pigeon-pair people so it's not an issue for us, but I was thinking that with 200Kg of fridge and 50 kg of food and drinks inside, it's not something Mrs P_D would be able to move in a hurry if the water line let go when I wasn't home*. Cheers, P_D *Things like this ONLY seem to happen to Mrs P_D, and ONLY when I'm not home !! . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27857 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 6007 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 10463 |
