Browse Forums Kitchen Corner Re: Anyone used a window for a splashback and any regrets? 2Mar 12, 2013 6:06 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Anyone used a window for a splashback and any regrets? 4Mar 12, 2013 8:32 am Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: Anyone used a window for a splashback and any regrets? 6Mar 12, 2013 12:13 pm Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Anyone used a window for a splashback and any regrets? 7Mar 12, 2013 12:38 pm Deposit paid to Masterton 30/05/13 Contracts signed and 5% deposit paid 09/10/13 CDC Approval 14/11/13 Slab 22/01/14 Frame 18/02/14 Brickwork 14/03/14 Roof 22/03/14 Lock Up 11/04/14 Re: Anyone used a window for a splashback and any regrets? 13Mar 31, 2013 5:35 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Anyone used a window for a splashback and any regrets? 14Mar 31, 2013 6:10 pm Jen Building with HomeGroupWA (started as Scott Park Homes ) - Grand Wisteria Check out my Build Thread!! Time line on P1. Re: Anyone used a window for a splashback and any regrets? 15Apr 02, 2013 10:00 am Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: Anyone used a window for a splashback and any regrets? 20May 22, 2013 12:36 am We will have a big window in the northern wall of our new kitchen. Unlike those pictured above, there won't be cupboards above it so we can have any size. I have to decide whether to have the bottom of the window at bench height, or 10 to 30cm above the bench so we have a tiled splashback under it. The sink will be in the middle, and I'm worried water will splash on the window & get in the window frame and be harder to clean. - ? I think I heard that it would cost more to have it line up with the bench because it's more fiddly - ? But then there'd be less tiling to do. Any pros & cons please! As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 18788 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18644 No. The same paint that they paint the wall with will be fine. The builder probably had every intention to paint it and not leave it black. 7 2876 |
