Land loan and construction loan
My concern is I wanted to get a construction loan together with land loan. I am in the process of talking to builder and getting draft plans but no build contract yet so I feel like I won’t make it on time for the finance or settlement clause for the land? It means I have to settle the land first then apply for construction loan, is that the only option I have?
What do bank need to for construction loan if combining with land loan as one? Do they need just the contract or do they need the plans already approved by council?
The main aim of this is to get as if complete valuation rather than at the end of the build.
Can someone shed some light I am confused...
if I settle on the land first then say a month after apply for construction loan and combine both loan together, will the bank do after completion valuation? It won’t be as if complete valuation?
With my above scenario (land finance due next week etc) what other options can I ask my broker and conveyancer?
Am I still allowed to request extension on finance or only on settlement now?
Thanks a lot in advance...
Firstly - to your extension, what state are you in?
What you’ve done sounds very normal. You can’t get the build loan approved without plans and a build contract (with only a couple of exceptions where they’ll use tender depending on state).
Typically I do:
Land loan fully approved
Preapproval for build
As if complete valuation for build
Build loan fully approved - this May or may not absorb the land loan.
The land will settle anywhere in that list.
Does it mean, as long as I have pre approval for build loan, I can settle on the land first then let’s say my build plans and contract is only finalised after land settlement so bank can only give me final approval of build loan after land has settled, bank will still do as if complete valuation for build?
Land loan approved
Pre approval for build
Land settlement
Build contract and plans submit to the bank
Bank will do as if complete valuation
Bank approve build loan
Combine build and land loan
Is above possible?
May I know what you mean with may or may not absorb the land loan with the build loan?
What does bank need for pre approval for build loan?
Thanks alot Bec
Regards,
Annie88
Yes you can do that exact sequence. Definitely they will do as if complete valuation at any time the build contract is ready.
For the preapproval they need the rough amount you want to borrow for the build - better still if you have a tender or quote.
And by absorb I mean combine the two loans
Hi Annie,
Typically I do:
Typically I do:
Hi,
Was just looking to see if anyone has already asked, and this thread maybe the closest.
Is there any advantages / disadvantages to doing separate loan (settle land first then construction loan) compare to combine loan together at once? We’re still waiting for our land to register and we’re pretty confident we can have our build plans and contracts in place even before the land settles.
Our deposit is less than 20% so we’ll be paying LMI.. i’ve read somewhere about double dipping of LMI when doing separate loans because it will be technically refinancing the land loan to combine to the 2 loans together. Though our broker mentioned about land valuation coming in over and thus could also be an advantage to doing separate loans.
Can anyone shed light?
Thank you!
Hi Annie,
Typically I do:
Typically I do:
Hi,
Thank you!
I'll pick up this and reply - the only way it double dips on LMI is if you change lender, otherwise the premium you pay for the build portion (in two separate loans example) is a "top up" based on the loan amount and eventual % you borrow.
There are realistically no advantages, except where timing helps you or there are special offers; eg:
1. aim to borrow 80% of the land (if possible) and cross your fingers the valuation goes up by the time you're ready to build
2. or, currently there are some special offers for no LMI to 85% on the land (only) - and these may expire depending on your registration time frame) but potentially take advantage of one of these then pay LMI on the build only.
Ask friends and family to refer you to a great broker local to you who can make sense of this overall for you
Hi Annie,
Typically I do:
Typically I do:
Hi,
Thank you!
Thanks so much for your response! This makes sense to me now
2
The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.…
29/08/2023
2
Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help
18/09/2023
1
Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes.
