Browse Forums Lighting + Lighting Design 1 Apr 21, 2009 10:22 am Hi all. Our local Current Affairs show last night had a story on how downlights are a fire risk. They say that there's one fire a week caused by downlights. We're planning on having lots of downlights throughout our new house. What's the risk? Is it if you install them yourself? (which we're not planning on doing). Is the type of insulation a problem? Are there better types of downlights that aren't as risky as others? I don't want our new house burning down just because we wanted pretty lighting! If we're put on this earth to help others, what are the others here for? Re: Downlights a fire risk? 2Apr 21, 2009 11:12 am This has been discussed before as it's quite important. Check out this thread : http://forum.homeone.com.au/viewtopic.php?f=8&t=9210&p=116728&hilit=downlight+fire#p116728 There are a few others - popular topic. Try the SEARCH function to bring up all related discussions. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Downlights a fire risk? 3Apr 21, 2009 11:17 am To avoid fire risk, don't use the low voltage downlights (the ones come with transformers), instead ask your builder to use the CFL (Compact Flourecent Lamp) 240 volts ones. Also, make sure that the lights are in a safe distance from your ceiling insulation. Re: Downlights a fire risk? 4Apr 21, 2009 12:32 pm They changed the standards about 12 months back because of the fire issue. Any new downlights installed have to be a certain distance away from flammable material or have a heat proof cover installed over them. Built with Bentley homes in Doreen All moved in Dec 2009 Now for the garden! Our stuff so far viewtopic.php?f=31&t=16532 Its never a good idea to sign a building contract without making sure everything is selected, soil test is done Is are dotted and Ts are crossed and without independent… 4 3254 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3952 Not back peddling at all. You seem to have issues with comprehension my friend. Guy fcked up, he's considering being dishonest with his bank and hiding it. It will end… 21 15050 |
