Browse Forums Lighting + Lighting Design Re: Opinions on square stainless steel downlights 5Aug 21, 2008 11:43 am 1st time bldrs, fussy and impatient! Re: Opinions on square stainless steel downlights 6Sep 01, 2008 12:21 pm Hi there waterhaven,
The pros & cons: - white ones will always discolour with extended use. with good quality downlights, this will be prolonged, as the powder coating will be of a superior grade as opposed to the cheaper ones. - the brushed aluminium ones are the most popular at the moment. - the square ones must be installed by an electrician "that cares" In short, don't cut corners by buying cheap quality fittings, and employing an electrician thats a cowboy. If you avoid these 2 points, you should be able to install any fitting you like, and it will look fantastic! Hope this helps. Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 7032 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14945 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6525 |
