Browse Forums Lighting + Lighting Design 1 Nov 26, 2017 8:58 am Hey all. Looking for some suggestions for what type of lighting you think would look good on my house. I'm going round and round in circles and just can't choose. You can see the light positions either side of the garage and I also have one under the verandah. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9014 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29432 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9336 |
