Browse Forums Lighting + Lighting Design 1 Jan 11, 2009 7:10 am We're renovating a 1930's apartment which has reinforcement columns in both corners of the living room (different dimensions - natch).
So we plan to fill in the space between the columns with a false Gyproc wall which will have recessed display shelves cut into it (something like the pic below). I've seen these lit with halogens from the top of the recess but also wondered if it might be better to install white glass as the base of the shelf and have lighting (flouroscent?) from below. Any thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Lighting for reccessed display shelves 2Jan 11, 2009 7:16 am Lighting from below won't suit many display items - a bust would look concave instead of convex...
But I like the idea... why not backlit white glass on the top surface? That would look special. Ed Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29414 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9322 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9003 |
