It's the one room all the mess ends up to be sorted and I'd rather not have to worry about maintenance of the flooring.
Spot on, it is the real utility area of the house so make it as user friendly as possible.
Cheers Lou
Browse Forums Flooring & Floor Covering Re: Flooring in laundry- advice before monday! 21Oct 11, 2010 5:57 pm mpcj I like tiles in the laundry, particularly when wet clothes, towels, shoes etc make their way to the floor I find them much easier to keep clean and not concerned with spills from the mop bucket or anything else. It's the one room all the mess ends up to be sorted and I'd rather not have to worry about maintenance of the flooring. Spot on, it is the real utility area of the house so make it as user friendly as possible. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Flooring in laundry- advice before monday! 22Oct 11, 2010 6:25 pm As others have mentioned, there are two reasons for having tiles in your laundry. 1) It's a wet area (with a floor drain) 2) It connects to the outside and it's good to have a buffer between the outside and timber flooring. If you have a stone stuck in your shoe you will hear it on a tile floor before you get to the timber floor. I've made sure that for each entry to the house there is tile or concrete (garage) before getting onto timber floor. Demolition August 2009, Construction Started September 2009, Completed December 2010 Agreed. I just found out today the certifier has not given the final sign off. 2 4239 Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added… 0 14325 Move your linen into laundry and access laundry from your present linen space 1 8340 |
